Calculating Frequency, Speed, and Tension of a Guitar String: Helpful Tips"
  • Thread starter Thread starter buffgilville
    Speed
The discussion focuses on calculating the frequency, speed, and tension of a guitar string with a length of 0.55 meters and a frequency of 283.23 Hertz. The linear density of the string is specified as 0.01 kg/m. The tension in the string can be calculated using the formula T = f² * linear density * wavelength². The wavelength is determined by the relationship between wave velocity and frequency, with the fundamental frequency indicating that the string vibrates with no nodes between its endpoints.
  • Understanding of wave mechanics and fundamental frequency
  • Knowledge of tension calculations in strings and ropes
  • Familiarity with linear density concepts
  • Ability to apply formulas related to wave speed and frequency
  • Learn how to calculate wave speed on a string using Tension and Linear Density
  • Study the relationship between frequency, wavelength, and wave speed in different mediums
  • Explore the effects of varying linear density on the tension and frequency of vibrating strings
  • Investigate the principles of standing waves and nodes in string instruments
Musicians, physics students, and educators interested in the mechanics of string instruments and wave behavior in physical systems.
buffgilville
1) The fundamental of a guitar string whose ends are a distance 0.55m apart has a frequency 283.23 Hertz. If the linear density of the string is 0.01 kG/meter, the tension of the string (in Newtons) is
T=f^2 * linear density * wavelength^2
f=283.23
linear density = 0.01
how do find the wavelength? I know that wavelength = velocity/frequency but the velocity of the wave on the string is not given. How does the fact that the guitar string's ends being 0.55m apart have to do with the tension of the string?
2) A heavy uniform rope is hanging freely from one end. The speed of a wave a distance 0.67 from the bottom of the rope (in meters/sec) is
how do I do this type of problem?
(1) Since this is the fundamental frequancy, the string is vibrating with no nodes in between. So,
[tex]\lambda=2L[/tex]
(2) Tension at distance x from bottom is [tex]\frac{Mxg}{L}[/tex] where M is the mass of the rope and L is the length.
So, divide it by the mass per unit length M/L, take the square root and you get the speed.
spacetime
www.geocities.com/physics_all
Thanks spacetime! :smile:
  • · Replies 23 ·
  • · Replies 29 ·
  • · Replies 26 ·
