| New Reply |
Calculating motor/calculator thrust |
Share Thread | Thread Tools |
| Oct11-11, 12:46 AM | #1 |
Hi I am building a quadro-copter, and i'm curious to know how i can calculate the thrust generated by a motor/propeller combo. The motors are brushless electric motors for which i know the max RPM. The propellers are two bladed for which the diameter and pitch are known. Is there a simple equation for which i can use in order to calculate the thrust/lift a particular combo will produce. Thanks.
| Dec16-11, 06:48 PM | #2 |
I am looking for an answer of the same problem, have you found anything meaningful?
| New Reply |
| Thread Tools | |
Similar Threads for: Calculating motor/calculator thrust
| calculating static thrust | Aerospace Engineering | 1 | ||
| Calculating Propulsive Efficiency Given Prop Diameter, Velocity, Thrust, and Altitude | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Calculating Tangents - Without the Calculator | General Math | 3 | ||
| Calculating 3^0.2 without using a calculator? | General Math | 32 | ||
| Need help calculating thrust! | Classical Physics | 1 | ||
