The discussion revolves around calculating thrust and impulse thrust for gas escaping from a pressure bottle, such as a scuba tank. Participants explore the mathematical relationships involved in determining the necessary parameters for achieving a specific energy output, including bottle size, pressure, and nozzle diameter.
- Technical explanation
- Mathematical reasoning
- Debate/contested
- One participant, Ben, seeks guidance on calculating thrust and impulse thrust for a gas escaping a pressure bottle, specifically asking for parameters needed to achieve 1MJ of energy output.
- Another participant discusses the relationship between pressure, force, and momentum, suggesting that impulse can be calculated using the formula for change in momentum and work.
- A different participant introduces the integral momentum equation of fluid dynamics, proposing a method to estimate exhaust velocity based on internal and external pressures.
- There are corrections and clarifications regarding the momentum integral equation, with one participant asserting that their previous statement was incorrect and expressing frustration over the mistake.
- Another participant humorously reflects on their own errors in the discussion, indicating a light-hearted approach to the technical challenges presented.
Participants express differing views on the correct application of fluid dynamics equations and the interpretation of momentum principles. There is no consensus on the best approach to calculate the required parameters for the thrust and impulse thrust.
Some participants acknowledge the complexity of the calculations involved, including the need for integration and the potential for varying conditions during gas escape. There are references to the need for more detailed analysis and the limitations of the initial approximations presented.
