How Does Charge Addition Affect Capacitor Potential in a Circuit with Resistors and Battery?
  • Context: Undergrad
  • Thread starter Thread starter lakshmi
    Capacitor Potential
The discussion clarifies how the addition of positive charges increases the potential difference across a capacitor's plates, while the addition of negative charges decreases it. It emphasizes that the potential difference is directly proportional to the amount of charge due to the constant ratio defined by capacitance. Furthermore, the presence of capacitors in a circuit with resistors and a battery affects current flow, causing it to increase and decay slowly. The conversation also highlights the complexities surrounding the definition of electric potential, stressing the importance of formal definitions over informal interpretations.
  • Understanding of electric potential and capacitance
  • Familiarity with basic circuit theory involving resistors and capacitors
  • Knowledge of charge interactions in electric fields
  • Basic grasp of units of measurement in physics (MKS system)
  • Study the relationship between charge and electric potential in capacitors
  • Learn about the effects of capacitors on transient response in RC circuits
  • Explore the formal definitions of electric potential and its measurement
  • Investigate the role of capacitors in energy storage and discharge in circuits
Electrical engineers, physics students, and anyone interested in understanding the dynamics of capacitors in electrical circuits.
lakshmi
how does the potential increases on adding positive charges and decreases on adding negative charges.
why does the the existence of capacitor does not have any effect in a circuit with resistors and battery
If you add charges, negative or positive, the potential difference between the plates of a capacitor increases. The reason is that always an equal charge of opposite sign in induced on a plate whenever you put a charge on another of the plates. So, since the ratio of charge and potential diff. is the constant ( and equal to capacitance ), the potential diff also increases.
Existence of capacitors has an effect on the circuit. The current increses slowly and decays slowly etc.
spacetime
www.geocities.com/physics_all
trouble
I have got into trouble before for this reply -- it is however true.
Potential is a very odd unit -- it is the amount of work done on a unit charge ( e.g. an electron ) in moving it thru an electric field from one place to another. the unit is therefore work ( joules ) per unit charge. specifically it is the work done in moving the unit charge from an infinite distance to the one under consideration. ( this is a precise definition )
It follows that if you move more than one charge then the potential is proportional to the number of charges . ( it just takes more work )
We have more misunderstanding of this unit than almost any other , because it envokes all sorts of images -- most of which are not true.
for instance volts are NOT a force . potential is not like temperature
there is NO absolute potemtial .
Because there are many definitions of the volt ( to do with how it maybe measured ) it is a really confusing situation.
However there is only ONE definition if you look at the units implied ( see dimensional analysis ) the basic metric is MKS -- meter kilogram second -- to which we have to ADD charge ( because it does not belong to the others ).
This is why the measure of potential includes our normal metric but adds charge.
What I am talking about here is the formal definition , NOT peoples idea of what this means . So take care and read up on any formal physics book for this definition.
My personal advice is NEVER look up a 'forum' for definitions , they are full of peoples opinions which for the most part are innaccurate , and totally biassed -- anybody who has the gall to call themselves a ' super mentor '
should be shot !
I do not know if this helps -- but it was a 'try'
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 58 ·
