Proving a complex Force derivation with CalcConfused
The discussion focuses on deriving the relationship between force, acceleration, and displacement in the context of a body moving along the x-axis under the influence of a force defined as F(v) = -Cv². The first part of the problem demonstrates that the net force leads to the equation x - x0 = (m/C) ln(v0/v) through two integrations of Newton's second law, ƩF = m dv/dt. The second part reformulates Newton's second law as ƩF = m*v*dv/dx, allowing for a single integration to derive the same expression for displacement.
  • Understanding of Newton's second law (F = ma)
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of ordinary differential equations and separation of variables
  • Concept of force as a function of velocity (F(v))
  • Study the method of separation of variables in ordinary differential equations
  • Learn about integrating factors and their application in solving differential equations
  • Explore the implications of force functions in physics, particularly in motion dynamics
  • Investigate advanced applications of Newton's laws in non-linear motion scenarios
Students and educators in physics, particularly those studying mechanics and dynamics, as well as anyone interested in the mathematical modeling of motion under variable forces.
BreakPoint
If we know F(t) the force as a function of time for straight line motion, Newton's second law gives us a(t) the acceleration as a function of time. We can then integrate a(t) to find v(t) and x(t). However, suppose we know F(v) instead. a) The net force on a body moving along the x-axis equals -Cv[itex]^{2}[/itex]. Use Newton's second law written as ƩF = m [itex]\stackrel{dv}{dt}[/itex] and two integrations to show that x - x0 = (m/C) ln(v0/v). b) Show that Newton's second law can be written as ƩF = m*v*[itex]\stackrel{dv}{dx}[/itex]. Derive the same expression in part (a) using this form of the second law and one integration.
F = ma
F(v) = -Cv^2
For the first part a), I had no idea so I started to differentiate the answer to try and get a method for simplifying it originally. The problem I encounter is that at X, If I take the 2nd derivative of the function I get a(t) = m/Cv^2, which seems impossible because you can't do that with -Cv^2 = m dv/dt. I solved that for dv/dt but i get nowhere really. I'm extremely stumped. Any pointers in the right direction would be extremely useful.
Thanks in advance.
For part a, you already know that
F = ma
F(v) = -Cv[itex]^{2}[/itex]
We can then write the following:
ma = -Cv[itex]^{2}[/itex]
a = [itex]\frac{-Cv^2}{m}[/itex]
[itex]\frac{dv}{dt}[/itex] = [itex]\frac{-Cv^2}{m}[/itex]
Next I will express [itex]\frac{-C}{m}[/itex] as some other constant to simplify the algebra. So let [itex]\alpha[/itex] = [itex]\frac{-C}{m}[/itex].
[itex]\frac{dv}{dt}[/itex] = [itex]\alpha v^2[/itex]
We can then use the method of separation of variables from ordinary differential equations to write:
[itex]\frac{dv}{v^2}[/itex] = [itex]\alpha dt[/itex]
[itex]\int \frac{dv}{v^2}[/itex] = [itex]\alpha \int dt[/itex]
You should be able to solve this integral for an expression for v. Then, if you isolate v you will be able to write v = dx/dt and repeat this procedure to find an expression for x.
  • · Replies 27 ·
  • · Replies 42 ·
  • · Replies 69 ·
