One skater pushes another skater
  • Context: Undergrad
  • Thread starter Thread starter MATRIX-K-
The discussion focuses on determining the masses of two skaters who together weigh 120 kg and push off from each other, achieving speeds of 3.3 m/s and 2.1 m/s. The principle of conservation of momentum is applied, stating that the initial momentum is zero, leading to the equation m1 * v1 + m2 * v2 = 0. By substituting the known values and solving the resulting equations, the individual masses can be calculated using the relationship between mass, velocity, and momentum.
  • Understanding of conservation of momentum
  • Basic knowledge of impulse and momentum equations
  • Familiarity with algebraic manipulation to solve equations
  • Concept of mass and velocity in physics
  • Study the principles of conservation of momentum in closed systems
  • Learn how to apply impulse-momentum theorem in various scenarios
  • Explore real-world applications of momentum conservation in sports physics
  • Investigate the effects of mass and velocity on momentum in different contexts
Students of physics, educators teaching mechanics, and anyone interested in understanding the dynamics of collisions and momentum in sports scenarios.
MATRIX-K-
I need to determine the masses of two skaters, who together weigh 120kg. They stand still opposite each other. Then they push each other away from away from each other. One of them gain the speed of 3,3m/s and the other one 2,1m/s.
How do you determine their masses?
I know it has something to do with impulses, but I can't figure it out...
This is a conservation of momtum proplem. Before the skaters push off their momentum is zero, so it must be after the push off. Can you take it from there?
[tex]\vec{p}=m\vec{v}[/tex]
where p is momentum. As Integral said,
[tex]\vec{p}_{initial}=\vec{p}_{final}[/tex]
You know initial momentum is zero, so find an expression for the final momentum and set it equal to zero.
  • · Replies 55 ·
  • · Replies 35 ·
