Calculating Spring Constant: Finding k Without Force Information
The problem involves calculating the spring constant of a massless spring that is compressed by a 1.0 kg mass. The spring is compressed by 17 cm to reach a new equilibrium position, and the original poster is unsure how to determine the spring constant without direct force information.
  • The original poster attempts to apply the formula F = -kx but expresses confusion about determining the force without explicit information. Some participants clarify that the weight of the mass provides the necessary force, leading to discussions about the relationship between mass, weight, and force.
Participants are actively engaging in clarifying the concepts of force and weight, with some guidance provided on how to calculate the force from the mass. There is an emerging understanding of the relationship between the mass placed on the spring and the resulting force, although explicit consensus on the final calculation has not been reached.
The discussion includes a focus on the definitions of force and weight, as well as the implications of Newton's second law in the context of the problem. The original poster's initial misunderstanding about force measurement units is also noted.
Flinthill84
I need a little help on this one:
One end of a massless spring is welded to a flat surface, the other points upward. A mass of 1.0kg is gently set down on top of the spring until the spring is compressed by 17cm to a new equilibrium position. What is the spring constant?
I know that you can find the spring constant by using F=-kx but I don't know how to find it without knowing the force. If anyone could help me I would greatly appreciate it. Thankyou!
Erm...you do know the force. The spring is compressed 17cm when a 1.0kg mass is placed on it. How much does 1.0kg weigh?
I thought that force was mass times acceleration though?
Yes, and if you multiply the given mass by the acceleration of gravity, then what physical quantity does that represent?
Force...so if I multiply the 1.0kg times 9.8m/s^2 I will get the force and therefore be able to calculate the spring constant
Newton's 2nd law says that the net force on an object equals mass times acceleration. The acceleration of the mass is zero, of course, so the net force on it is zero. The two forces acting on the mass--its weigh (pulling down) and the spring force (pushing up)--must exactly balance. So the spring force must equal the weight of that 1.0kg mass.
alright I hope I am understanding this correctly...from what I understand that your telling me the force is just the 1.0kg? if that is correct I though force had to be in Newtons?
The force is the weight of the 1.0kg mass. You can calculate the weight as Tom explained, by multiplying the mass by the acceleration of gravity. And it will be in Newtons.
ok I understand now...thankyou very much!
  • · Replies 17 ·
