Working with functions defined by Interpolation in Mathematica
This discussion focuses on using the "Interpolation" function in Mathematica to solve for one variable in a two-variable function when the other variable and the function's value are known. The user Evgeniy demonstrates how to find the value of x given y and z using numerical methods, specifically the FindRoot function. A sample dataset is provided, and the results show that the interpolation method yields a close approximation to the expected value. Additionally, the InverseFunction method is introduced as an alternative approach to achieve the same result.
  • Familiarity with Mathematica programming language
  • Understanding of interpolation methods in numerical analysis
  • Knowledge of numerical root-finding techniques, specifically FindRoot
  • Basic concepts of function visualization using ContourPlot
  • Explore the "FindRoot" function in Mathematica for solving equations numerically
  • Learn about "InverseFunction" in Mathematica for solving inverse problems
  • Investigate advanced interpolation techniques in Mathematica, such as "InterpolationOrder"
  • Study the use of "ContourPlot" for visualizing multi-variable functions in Mathematica
Mathematica users, data scientists, and researchers who need to solve multi-variable equations and optimize interpolation methods for numerical analysis.
evgenx
Working with functions defined by "Interpolation" in Mathematica
Hello,
Just perhaps a simple question for a Mathematica expert:
I have a function of two variables f(a,b) defined using Interpolation option
in Mathematica. I am wondering how to determine the value of one of the
variable if I know the value of the other variable and the value of the function.
Many thanks!
Evgeniy
So you know f[x,y]==z for some y and z
Then to find x you need to use a numerical method to find when f[x, y] - z == 0.
Note that, depending on the function, this solution won't necessarily be unique.
Anyway, here's a test function:
data = Flatten[Table[{{x, y}, E^(x + y)}, {x, 4}, {y, 4}], 1]
f = Interpolation[data]
which you can visualize using
ContourPlot[f[x, y], {x, 1, 4}, {y, 1, 4}]
Then if, e.g., y=3, z=140, what does x = ?
In[]:= FindRoot[f[x, 3] == 140, {x, 2.5}]
Out[]= {x -> 1.93157}
Check:
In[]:= Exp[4.93157]
Out[]= 138.597
It's not exactly right, but pretty good considering how few points were used for the interpolation.
In general you can construct a function that gives the solution using InverseFunction:
In[26]:= Solve[g[x, y] == z, x]
Out[26]= {{x -> InverseFunction[g, 1, 2][z, y]}}
So
In[28]:= InverseFunction[f, 1, 2][140, 3] // N
Out[28]= 1.93157
which matches the FindRoot approach (and probably uses the same or similar algorithm internally).
