Proof of Set Function f(f^-1(Y'))\subseteqY
  • Context: Graduate
  • Thread starter Thread starter autre
    Function Proof Set
The discussion revolves around proving the set inclusion f(f^-1(Y')) ⊆ Y' for a function f: X -> Y and a subset Y' of Y. Participants explore the implications of the definitions involved and the conditions under which the proof holds, including considerations of surjectivity and injectivity.
  • One participant proposes starting with y ∈ f(f^-1(Y')) and attempts to derive the proof from this definition.
  • Another participant questions the notation used, pointing out a potential misunderstanding regarding the relationship between sets and elements.
  • A revision of the proof is suggested, emphasizing the need to clarify the relationship between f^-1(Y') and the elements of X.
  • Concerns are raised about assuming properties of f, such as bijectivity, which may not hold in general cases.
  • Participants discuss the implications of f not being surjective, noting that this could affect the existence of certain pre-images.
  • One participant suggests applying the definition of y ∈ f(A) to clarify the proof structure.
  • A later reply indicates that the proposed reasoning seems acceptable but does not confirm its correctness.
Participants express uncertainty about the proof's validity and the assumptions made regarding the function f. Multiple competing views remain regarding how to handle cases where f is not surjective or injective, and the discussion does not reach a consensus.
Limitations include the dependence on the properties of the function f, such as whether it is bijective, and the implications this has on the proof. The discussion does not resolve these limitations.
autre
I need to prove f(f^-1(Y'))[itex]\subseteq[/itex]Y' for some f: X -> Y and Y' in Y.
So far, I've been able to figure this much out:
Let y[itex]\in[/itex]f(f^-1(Y')). Then, f^-1(Y') = x' for some x' in X such that f(x') = y' for some y' in Y'. Then, f(x') = y'. Thus, f(f^-1(Y'))[itex]\subseteq[/itex]Y'.
I feel like there's something wrong with my proof. Any ideas on where I went wrong?
Any ideas?
You probably mean Y' subset of Y.
What does that even mean?? Y' is a set, so [itex]f^{-1}(Y^\prime)[/itex] is a set. But x' is an element. So you're saying that a set is equal to an element?
Start with [itex]y\in f(f^{-1}(Y^\prime))[/itex]. Write out the definitions. What is the definition for [itex]y\in f(A)[/itex]??
Thanks for the input micromass.
I've revised the proof as thus:
Let y∈f(f^-1(Y')). Since f^-1(Y') = X' s.t. X'⊆X and f(X')=Y'. Since y∈f(X'), y∈Y'. Thus, f(f^-1(Y'))⊆Y'.
I still feel like I'm missing a step or two.
Why??
This would imply
[tex]f{-1}(f(X^\prime))=X^\prime[/tex]
which does not always hold.
Why??
You're right, I can't assume f is bijective. Should I instead say something like "there exists an x∈X s.t. x∈f^-1(Y')?
Maybe a good comment to make is that, in the nicest-possible case, you have:
f-1of(X)=fof-1X=X.
Nicest possible is, of course, f is 1-1 and onto. Try to see why identity above fails when f is either not 1-1 or not onto.
TMFKAB (The Mathematician* Formerly Known as Bacle)
*In training.
Not sure how that helps, Bacle2. Basically, if the function isn't surjective there could exist a b in B' such that f^-1(B') doesn't exist, and I'm not sure how to handle this case.
Bacle wasn't giving you a hint to solve the problem. He gave you another problem which could be rewarding to look at to expand your knowledge.
To solve your problem. What does it mean that [itex]y\in f(A)[/itex]. Apply this to [itex]y\in f(f^{-1}(y))[/itex].
What does it mean that y∈f(A). Apply this to y∈f(f−1(y)).
I think I follow. You mean something like:
Let y∈f(f^-1(Y')). Then, there exists an x in f^-1(Y') s.t. f(x) = y. Since x in f^-1(Y'), f(x) = y for some y in Y'. Thus, f(f^-1(Y'))⊆Y'.
Seems ok.
Yes, Autre, sorry if my post was confusing; just trying to give some insight and some related results, as Micromass said.
