| New Reply |
System of ODEs |
Share Thread | Thread Tools |
| Oct13-11, 03:41 PM | #1 |
System of ODEs
Consider the following system of equations da/dt = -kab, db/dt = kab, a(0) = a0, b(0) = b0. Solve these equations exactly. 2. Relevant equations 3. The attempt at a solution I added them together to get d(a+b)/dt = 0 which implies a + b = a0 + b0. Therefore a = a0 + b0 - b so eliminating a we get db/dt = k(a0 + b0 - b)b which is separable, but I don't know where to go from here. Someone please help. |
| Oct13-11, 04:10 PM | #2 |
Mentor
[tex]\frac{db}{b(a_0 + b_0 - b)} = k\cdot dt[/tex] The left side can be integrated by using partial fraction decomposition. You could simplify the work slightly by rewriting a0 + b0 as, say, M. |
| Oct13-11, 05:02 PM | #3 |
Thanks.
I let M = a0 + b0 and got 1/(b(M-b)) = 1/(Mb) + 1/(M(M-b)) and this integrates to (ln(b)-ln(M-b))/M, therefore we get (ln(b)-ln(M-b))/M = kt + c, so ln(b/(M-b)) = M(kt+c), so b/(M-b) = exp(M(kt+c) but what do I do now. |
| Oct13-11, 06:01 PM | #4 |
Mentor
System of ODEs
Then b = (M - b)exp(M(kt + c))
==> b - bexp(M(kt + c)) = Mexp(M(kt + c)) ==> b(1 - exp(M(kt + c))) = Mexp(M(kt + c)) ==> b = ? You should be able to get rid of the constant c, since you are given that b(0) = b0. Finally, since a and b add up to a constant, you can solve for a. When you get a, by all means, check your work. Check that a(0) and b(0) turn out as expected, and then check that a'(t) = -kab, and that b'(t) = -a'(t). |
| Oct13-11, 07:19 PM | #5 |
We get b = Mexp(M(kt+c))/(1-exp(M(kt+c))
so b(0) = b0 = Mexp(Mc)/(1-exp(Mc)), but how do we find c? |
| Oct13-11, 07:35 PM | #6 |
Mentor
==> b0 - b0exp(Mc) = Mexp(Mc) ==> b0 = b0exp(Mc) + Mexp(Mc) = exp(Mc)(b0 +M) ==> b0/(b0 +M) = exp(Mc) Now take the ln of both sides. |
| New Reply |
| Thread Tools | |
Similar Threads for: System of ODEs
| A System of Three ODEs | Calculus & Beyond Homework | 1 | ||
| From a System of 1st ODE to a 2nd ODE and back to the system of 1st ODEs | Differential Equations | 1 | ||
| system of ODEs | Differential Equations | 2 | ||
| a pendulum system and ODEs | Differential Equations | 1 | ||
| System of ODEs | Introductory Physics Homework | 1 | ||
