Operations on irrational numbers
The discussion revolves around operations on irrational numbers, specifically exploring the conditions under which the product or sum of two irrational numbers results in a rational or irrational number. Participants examine proofs related to irrationality and consider counterexamples, leading to questions about the nature of irrational numbers in arithmetic operations.
  • Some participants propose that if the product of two numbers \(pq\) is irrational, then at least one of \(p\) or \(q\) must be irrational, and similarly for the sum \(p + q\).
  • Counterexamples are suggested, such as \((\sqrt{a})^2\) for products and \((a + \text{irrational}) + (a - \text{irrational})\) for sums, raising questions about the validity of these proofs.
  • One participant introduces the concept of transcendental numbers, suggesting that for any two transcendental numbers \(x\) and \(y\), either \(x+y\) or \(xy\) must be transcendental.
  • Another participant discusses the existence of two irrational numbers, specifically \(\sqrt{2}^{\sqrt{2}}\) and \(\sqrt{2}\), that can multiply to yield a rational number, \(2\).
  • Concerns are raised about the structure of irrational numbers, with a participant noting that the presence of rational elements (0 for addition and 1 for multiplication) complicates the formation of interesting structures among irrationals.
  • Examples of pairs of irrationals that sum to a rational number are provided, including the idea that every irrational can be expressed as a sum of a rational and an irrational component.
  • Discussion includes the notion that the distinction between contrived and natural examples of sums of irrationals leading to rationals is subjective.
Participants express differing views on the conditions under which operations on irrational numbers yield rational or irrational results. There is no consensus on the validity of the proposed counterexamples or the implications of the discussed properties of irrational numbers.
Participants note that certain operations may not yield new insights, as they often revert to original values or involve rational components. The discussion highlights the complexity of defining and working with irrational numbers in arithmetic.
Acid92
Heres two problems from an A Level related paper: prove that if pq is irrational then atleast one of p or q is irrational. Also prove that if if p + q is irrational then atleast one of p or q is irrational. These two proofs are trivial proof by contradiction problems but it got me thinking more about cases where operations on two irrational numbers result in irrational or rational numbers
Now what's interesting are the inverses of the statements, i.e. if atleast one of p or q is irrational then pq is irrational and if atleast one of p or q is irrational then p+q is irrational.
I can think of two seemingly counter examples to both but they still leave some questions. To the first clearly anything of the form (sqrt(a))^2 is counterexample and the second something like (a + irrational number)+(a - irrational number).
The question that is remaining is: Other than the case of square roots squared and any other special case, can two normal different irrational numbers multiply to give a rational number? And can two irrational numbers add or subtract to give a irrational number which does not involve cancellation of the irrational parts?
The answer seems to be an intuitive "no" because both can't involve cancellation but here's a way of looking at things that just makes everything confusing, consider the special case of like (sqrt2)^2, we can break it into the sum of a rational and irrational part namely
(1+ir)^2 where ir is the irrational part then
(1+ir)^2 = 1 +2ir + ir^2 = 2
Now here's two seemingly irrational numbers 2ir +ir^2 that give a rational, what's going on? What about subtraction and division of irrationals?
I think you are talking about http://en.wikipedia.org/wiki/Transcendental_number" .
I don't think you know what http://en.wikipedia.org/wiki/Normal_number" means.
In general, given any two transcendental numbers, x and y, then either x+y or xy must be transcendental (or both).
Lastly consider this: there exists two irrational numbers such that xy is rational. Consider [itex]\sqrt{2}^{\sqrt{2}}[/itex]. If this is rational we are done. If not let this number be x, and let y equal square root 2. So that xy=2. QED.
normally, with any kind of "structure" (i am using the word loosely here), if there is a distinguished element (a 0-object), and you wish to make a subset a "substructure", the subset has to contain the 0-object.
with addition, the 0-object is 0.
with multiplication, the 0-object is 1.
both of these are rational, which effectively kills the chances of the irrationals having any interesting self-contained structure (at least ones involving ordinary arithmetic functions).
what you might be interested in, is studying fields of the form Q(√k) where k is a positive integer that is not a perfect square. this might answer your question about how certain "special" sets of irrational numbers can interact.
I think what you're asking is if there are examples that don't seem contrived. For example, 3 - pi and 3 + pi are irrationals that sum to a rational; but one could say, well, those are obviously contrived examples ... is there a more "random" or natural looking example?
First, there are quite a lot of examples of pairs of irrationals that sum to a rational. Given any irrational, consider its decimal expansion. Any finite truncation of the expansion expresses that irrational as the sum of a rational and an irrational. For example take pi = 3.14159...
I can say that pi = 3 + .14159... or pi = 3.1 + .04159... and so forth. In other words every irrational is the sum of a finite truncation of its decimal expansion, plus the tail remaining after the truncation.
Now, for each of those pair, just combine the irrationals to get a pair of irrationals that sum to a rational. For example pi = 3 + .14159, so pi - .14159... = 3. That's a sum of two irrationals that's rational. So you can see that there are lots and lots of these kinds of examples that appear "normal," but are actually contrived.
Did you know that it is unknown whether e + pi is rational or not? That's quite amazing. If their sum were to turn out to be rational, that would be as normal or non-contrived example as you can imagine, I think.
I didn't answer your question, but I hope I have you more to think about. Every irrational is the sum of a rational and an irrational in many different ways; so in the end, it's likely that every "normal" appearing rational sum of irrationals, it's really a contrived example at some level.
You can pursue similar reasoning for multiplication. In the end, the "contrived versus natural" distinction is artificial and more a matter of psychology than mathematics. Some numbers just look more random than others.
Acid92 said:
. To the first clearly anything of the form (sqrt(a))^2 is counterexample and the second something like (a + irrational number)+(a - irrational number). ...Now here's two seemingly irrational numbers 2ir +ir^2 that give a rational, what's going on? ?
nothing special,
in both cases you are not doing any operation: x [+y -y] = x , x [√ ²] = x
in the first example x = 2, in the second [(ir=√2-1), 2ir+ ir²] x = 1: 1 [+(2√2-2) + (2 -2√2)] = 1
When you truncate a real to x decimal digits, you can perform division and any other operation.
P.S. when you say rational + ir, remember also 1/7 is defined as rational
  • · Replies 85 ·
9K
