Values of Velocity at which the body will move without bouncing
  • Thread starter Thread starter sodaboy7
    Body Velocity
The problem involves a point mass attached to a rigid hoop that rolls without slipping on a horizontal plane. The inquiry focuses on determining the velocity at which the hoop can move without bouncing when the point mass reaches its lowest position.
  • Participants discuss the conservation of energy as the point mass gains potential energy while moving up, affecting the kinetic energy of the system. There is also mention of the conditions under which the hoop might bounce due to centrifugal force when the mass is at its highest point.
Some participants are questioning the validity of the solution they found, expressing skepticism about its appropriateness and seeking clarification on the reasoning behind the derived answer. Multiple interpretations of the problem's dynamics are being explored.
Participants note potential real-world factors, such as imperfections in the hoop and surface, that could influence the behavior of the system, suggesting that practical considerations may complicate the idealized scenario presented in the problem.
sodaboy7
A small point mass is fixed to the inside of a thin rigid ring(hoop) of radius R and mass equal to that of the point mass. The hoop rolls without slipping over on a horizontal plane; at the moments when the point mass gets into lower position, the center of the hoop moves with velocity V0. At what values of V0 the hoop will move without bouncing ?
2. The attempt at a solution
As the point mass m attached to the hoop moves up it gains potential energy. Since total energy must be conserved, the kinetic energy of the (hoop+point mass system) reduces and thus the rotating hoop slows down. the hoop will have its maximum tendency to jump off the ground when the point mass is located at the highest point due to centrifugal force, that's all I can think about.
Does this make sense?
Edit, in my sketch my v = 2V_o
In a perfect world, no bouncing, just diminished G's. In the real world, imperfections in the hoop and "road" surface could easily create bouncing. Isn't this why we balance rotational bodies?
