Can Airflow Through Floor Vents Be Regulated to Minimize Loss in High Winds?
  • Thread starter Thread starter numbnah
The discussion revolves around the regulation of airflow through a floor vent designed for the removal of waste gases from a heating system, particularly in the context of high wind conditions. Participants explore potential measures to minimize air loss without compromising safety or functionality.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests using baffles or a solid enclosure to reduce airflow through the vent during high winds.
  • Another participant questions whether a solid enclosure would restrict the necessary flow of waste gas through the vent.
  • A later reply emphasizes the need for more information to provide a better response, indicating that the initial suggestion may not be fully informed.
  • It is clarified that the vent is specifically designed for the removal of LPG waste gases and cannot be blocked or covered.
  • One participant expresses concern about the safety of having LPG present in the structure, suggesting that it should be contained or burned to prevent hazards.
  • A suggestion is made to create a governor or throttle to regulate the airflow through the vent.
Participants express differing views on the feasibility and safety of proposed solutions, with no consensus reached on the best approach to regulate airflow while ensuring safe waste gas removal.
Participants note the importance of maintaining safe ventilation for waste gases while attempting to mitigate the effects of high wind on airflow. The discussion highlights the complexity of balancing safety and functionality in the proposed solutions.
numbnah
Vent in a floor, the vent is designed to remove waste gases from a heating system and consists of a grill cut into a timber floor. (15cm x 15cm in size)
The floor the vent is fixed into is suspended above ground and is exposed so that wind and other external factors can have an affect on how much air is drawn through the vent in certain weather conditions. ie strong winds draw out more air from the internal structure.
My question is this, what measures could be taken to reduce air loss through the floor vent in high wind conditions without covering the vent or hindering safe removal of waste gas?
Thank you gentlemen.
Baffles, or better yet some solid enclosure.
Would the solid enclosure not restrict the flow of waste gas through the vent?
In actual fact, that was just a "top of my head" response based upon limited input. You really have to provide a lot more information about the situation before anyone can provide a better response. Russ might be your best bet for info on this, since he's the resident HVAC specialist.
The vent in the floor is designed to remove waste gas (LPG) it is not required to provide clean air to the building interior.
The vent is cut into a timber floor and consists of a grill, the grill just vents to the outside.
The floor is suspended about 60cms from the ground and is open to external elements, primarily wind passing beneath the structure.
Because the vent is floor mounted and is designed as a safety measure to remove LPG gas waste etc the vent cannot be blocked or covered to reduce air flow.
My understanding is that as the wind speed beneath the floor increases then so does the amount of air it draws through the vent ( i presume this is because of the difference between internal and external air pressure)
Is it possible to fit something beneath the floor (and the vent) to reduce the effects the high wind speed would have on drawing air from the internal space, without reducing the removal of waste gas from the LPG heating system?
I am trying to find a way of reducing the amount of air being drawn through the vent in high wind conditions to the floor space below, while still maintaining safe ventilation of waste gases.
Thank you
I hope that is a little more clear
Well, it's a more detailed explanation, but one glaring detail eludes me. Why the hell do you have LPG flying around loose in a structure? It should be either contained or burned. I seems to me that you have a bomb just waiting for an excuse to detonate.
Could you make a governor or throttle that will regulate the airflow?
  • · Replies 21 ·
9K
