How to Evaluate a Cauchy Integral on Different Paths?
The discussion focuses on evaluating the Cauchy integral of the function dz/((z-i)(z+1)) over the contour C defined by |z-i|=1. The Cauchy integral formula is applied, highlighting that the function 1/(z+1) is analytic within this contour, while the contour |z|=2 includes two poles at i and -i. The evaluation of residues at these poles is emphasized as the simplest method for solving the integral, with the first contour enclosing one pole and the second enclosing two.
  • Understanding of Cauchy integral formula
  • Knowledge of analytic functions
  • Familiarity with residue theorem
  • Basic concepts of complex analysis
  • Study the application of the residue theorem in complex analysis
  • Learn about contour integration techniques
  • Explore the implications of poles and singularities in integrals
  • Investigate the differences between various contour paths in complex integrals
Students and professionals in mathematics, particularly those specializing in complex analysis, as well as anyone interested in advanced integration techniques and the properties of analytic functions.
redshift
Cauchy integral question
The question calls for finding the integral of dz/((z-i)(z+1)) (C:|z-i|=1)
I can't figure out how to do this for (C:|z-i|=1). How does this differ from, say, (C: |z|=2)
Regards
One way to evaluate this integral is by using the Cauchy integral formula:
[tex]f(z)=\frac{1}{2\pi i}\oint_C \frac{f(\zeta)}{\zeta-z}d\zeta[/tex].
Which holds f is analytic on and inside C and z is any point inside C.
Notice [tex]\frac{1}{z+1}[/tex] is analytic inside (C:|z-i|=1).
This would not be the case for (C: |z|=2).
the difference between the two circles is in the number of poels inside them, as galileo observed. i.e. the simpelst way to do this integral is by evaluating residues att he poles inside the path. the first path contains one pole, the one at i, and the second path contains two, poles, at i and -i.
the tool is based on local expansions. and cauchy's theorem.
i.e. 1/z is basically dln(|z|) + 2pi idtheta, so when you integrate it around a lop inclosing 0, you get 2pi i.
the same holds if you shift to other points. so 1/(z-i) gives 2pi i when integrated around i, and 1/(z+i) gives 2pi i when intregrated around -i.
each is holomorphic near the other's pole so 1/(z-i) e.g. gives zero when integrated around a small circle centered at -i.
  • · Replies 21 ·
