What is the Most Effective Angle for Blowing on Hot Coffee to Cool it Down?
  • Context: Undergrad
  • Thread starter Thread starter curiouscow393
    Angle Coffee
The optimal angle for blowing on hot coffee to cool it down is approximately 60 degrees, as determined by an experiment measuring temperature changes at various angles (0°, 30°, 45°, 60°, 75°, and 90°) using an electric pump. The initial coffee temperature ranged from 88°C to 91°C, and the results indicated that blowing at 60 degrees increased surface area and enhanced evaporative cooling. Factors such as air stream power, container shape, and the need for stirring to achieve uniform temperature were also discussed as influential variables in the cooling process.
  • Understanding of thermodynamics, specifically heat transfer and evaporative cooling.
  • Familiarity with experimental design and data collection methods.
  • Knowledge of fluid dynamics, particularly convection currents in liquids.
  • Experience with temperature measurement techniques and equipment.
  • Research the principles of evaporative cooling and its applications in thermal management.
  • Learn about fluid dynamics and how convection affects heat distribution in liquids.
  • Explore experimental design best practices, including the importance of error bars and systematic error analysis.
  • Investigate the impact of container shape on heat retention and cooling rates in liquids.
This discussion is beneficial for physicists, experimental scientists, and anyone interested in thermodynamics, particularly those studying heat transfer methods and fluid dynamics in practical applications.
curiouscow393
My friends and I were curious as to what the best angle was to blow on coffee to cool it down (actually only the coffee near the surface cools, so that's where we measured)
We did three trials each for 0°, 30°, 45°, 60°, 75°, and 90°.. all started around 88°C to 91°C measured every 30 seconds for 3 minutes while blowing on it with an electric pump (opening modified to simulate lips)
We got this result, graph of average degrees per second as a function of blowing angle
http://img11.imageshack.us/img11/9660/screenshot20111017at102.png
Uploaded with ImageShack.us
Aside from the air blowing away the vapor-saturated-air to keep evaporation going, we think we got this result because blowing down 60° caused an increase in surface area (by pushing down the water slightly on one side) and we think that the graph went down towards the end because surrounding pressure became greater than vapor pressure so evaporative cooling became less.
What do you guys think?
Btw, the red dot was the control, no blowing involved.
Science news on Phys.org
Wait...did you actually do this experiment? If so, you're awesome. Was it for a school project or something?
Anyway, there's lots to take into account. I'm guessing the power of the air stream would definitely change the optimal angle. You'd also have to specify exactly what the liquid does when the air hits it. Also, the shape of the container it is in probably matters a great deal.
My bet would be the shape of your coffee cup... blowing at the 60 degree angle could be the best by causing the coffee to flow and help convection currents bring the hotter coffee to the surface, more so than the other angles anyways.
interesting experiment lol
Did you have the coffee filled to the brim of the mug, so that the air would always hit the surface of the coffee and not hit the inside of the mug at low angles? Or did you have it filled to a level more characteristic of normal drinking practices?
My coffee maker doesn't make the coffee scaldingly hot, I never need to worry about this.
Great experiment.
Did you stir the coffee to obtain an even temperature of the liquid throughout or just the top surface?
I don't think I could blow on coffee for 3 minutes.
Most people will blow on hot coffee a bit and then sip.
60 degrees from the normal?
If you didn't stir it, blowing at an angle induces convection which hastens cooling.
Beyond some angle, the air comes in glancing, which reduces its effect.
so probably 30 degrees from normal haha.
Interesting idea, but graphs of measured data like this are actually nearly useless unless you put error bars on the points, and that is often the hardest part of experimental physics. :smile: The reader has no idea if the results are significant, or if the uncertainty in the measured points is as large as the whole vertical scale, even if you do include 8 significant figures in the rate table. To include error bars, you'll need to consider how accurately the angles were measured, and more importantly how accurately the temperatures and rates of change of temperatures were measured. There are also possible systematic errors, due for example to the height of the level of the coffee relative to the rim of the cup, the distance to the electric fan, etc.
Chill.
dacruick said:
Chill.
Dude.
JeffKoch said:
Dude.
duuuude
Lol!
9K
