Register to reply
Pendulum Problem: Potential energy equals? kinetic energy
by smeiste
Tags: energy, equals, kinetic, pendulum, potential
Share this thread:
smeiste
#1
Oct16-11, 09:36 PM
P: 36
A pendulum consists of an object of mass m = 1.65 kg swinging on a massless string of length l. The object has a speed of 1.97 m/s when it passes through its lowest point. If the speed of the object is 0.87 m/s when the string is at 70 below the horizontal, what is the length of the string?
Correct answer: 2.64 m (to 3 sig figs)
2. Relevant equations
Ep = mgh
Ek = 1/2mv^2
3. The attempt at a solution
I tried the equation:
mg(length(1-cos20)) = 1/2mv^2
and this did not work.. it worked when I had the length and needed the velocity?
Phys.Org News Partner Science news on Phys.org
Sapphire talk enlivens guesswork over iPhone 6
Geneticists offer clues to better rice, tomato crops
UConn makes 3-D copies of antique instrument parts
PeterO
#2
Oct17-11, 07:00 AM
HW Helper
P: 2,316
Quote Quote by smeiste View Post
Ep = mgh
Ek = 1/2mv^2
Using your two speeds, you can calculate the kinetic energy at the bottom, and when in the 70 degree position [or indeed 20 degree as you are starting to use]
The reduction in kinetic energy will be accompanied by an equivalent increase in Potential energy - so you know the gain in height.
A bit of trig on the triangle formed should yield the pendulum length you are after.
smeiste
#3
Oct17-11, 12:41 PM
P: 36
Thank you so much!
Register to reply
Related Discussions
Work-Energy Theorum: Spring potential energy vs Kinetic Energy Introductory Physics Homework 4
Ballistic Pendulum - Kinetic Energy vs Gravitational Potential Energy General Physics 13
Finding x when Elastic Potential Energy equals Kinetic Energy Introductory Physics Homework 3
Ballistic pendulum change in kinetic energy problem Introductory Physics Homework 4
Potential Energy and Kinetic Energy Problem Introductory Physics Homework 13
