New Reply
Can Static energy generate magnetic field?
Share Thread Thread Tools
Oct18-11, 10:17 AM   #1
Referring to following image, static energy is generated, do we detect any magnetic field around this area? If we only get pure positive or negative charge on stable object, will it generate any magnetic field?
On the other hands, is there any digital device to measure the strength of static energy?
Does anyone have any suggestions?
Thanks in advance for any suggestions
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Oct18-11, 06:48 PM   #2
In classical E&M magnetic fields are created by moving charges or time varying E fields, so if your source charges are stationary there should just be an E field.
you could use a charged ball on a string like a pendulum to measure the E field.
Or if you want to measure B fields you would use a hall probe.
Here they calculate the charge on a ball in an E field.
http://www.physicsforums.com/showthread.php?t=176363
Oct27-11, 02:30 AM   #3
Do you know what kind of charges on the surface of the ball? Positive or Negative charges?
Thanks you very much for any suggestions
Oct27-11, 05:15 AM   #4
If there is no moving charge or changing field there is not likely to be detected by a stationery object like a compass. But it seems that electric and magnetism can easily transform from one to another in different reference frames.
Oct27-11, 10:07 AM   #5
Recognitions:
Gold Membership Gold Member
no, if the observer is stationary with respect to the apparatus,
yes, if the obserber is in relative motion with respect to the apparatus.
Oct27-11, 09:26 PM   #6
Quote by Naty1 View Post
I see, no movement, no magnetic field,
Does anyone know about this device on what kind of charges generate on the surface of the ball? Positive or Negative charges? I would like to purchase one, where can I purchase a small one?
Oct28-11, 12:27 AM   #7
You can have generators which create negative charges on the surface and others which will create positive charges, you'd have to check with whoever you're buying it from :)
New Reply
Thread Tools
Similar Threads for: Can Static energy generate magnetic field?
Thread Forum Replies
How can a single moving charge generate a magnetic field relativistically General Physics 34
Static magnetic field question HELP! Advanced Physics Homework 1
induced current in a static magnetic field General Physics 7
Static Magnetic Field and Work Advanced Physics Homework 7
Static Magnetic Field Theory Introductory Physics Homework 0
