Thread Closed
How to create PDF documents and write in LaTex?
Share Thread Thread Tools
Nov25-04, 05:23 PM   #1
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
What do I need to do to be able to create PDF documents and be able to write in LaTex in them like on this forum?
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Nov25-04, 07:14 PM   #2
Admin
One way is to write text in MS Word or other word processor, do equations in a LaTeX interpreter, and copy the equations and paste them as a bitmap into the Wordprocessor text file.
If Adobe Acrobat is installed and integrated properly, one should be able to convert the Word (or other wordprocessor) file into a pdf. This is the method I use at work.
Or one can do text and equations in LateX, but I don't know if the file can then be imported into Acrobat.
Nov25-04, 07:37 PM   #3
Recognitions:
Try using pdflatex. Instead of rendering to a dvi file, it renders to a pdf.
Nov25-04, 07:59 PM   #4
Mentor
Check out this PDF printer
Nov25-04, 08:32 PM   #5
Recognitions:
If you want to write something that is mathematically-intensive, use LaTeX directly, not any other kind of word processor. Then process the document with pdflatex, as graphic7 advises. LaTeX is not just a formula writer; you can write whole articles, papers, books,... with it.
Dec5-04, 02:50 PM   #6
Type your paper in a text editor and save it with the extension .tex You can then compile this source file to a DVI file by typing
latex <filename.tex>
The DVI can be converted to a pdf file by using dvipdfm:
dvipdfm <filename.dvi>
Dec6-04, 01:29 AM   #7
you could get a mac... Os X has system wide save as PDF :-)
Thread Closed
Thread Tools
Similar Threads for: How to create PDF documents and write in LaTex?
Thread Forum Replies
Creating PDF documents? Calculus & Beyond Homework 7
How do I write with Latex? General Math 3
If the CBS documents are frauds should CBS expose the source? Current Events 18
Diana: Secret Documents Revealed Current Events 0
SCI FI Channel may sue US gov't for UFO documents Science Fiction & Fantasy 25
