Optimizing Pendulum Period: Using a 1.0 m Stick for Maximum Results
  • Thread starter Thread starter physicsss
The discussion revolves around optimizing the period of a pendulum using a 1.0 m stick. The original poster seeks to determine the optimal point to drill a hole in the stick to achieve the shortest oscillation period, questioning the relationship between the position of the hole and the period of the pendulum.
  • Participants explore the formula for the period of a physical pendulum and discuss the implications of different positions for drilling the hole. There are attempts to derive the period mathematically and questions about the correctness of assumptions regarding the optimal position.
Participants are actively engaging with the mathematical expressions and questioning the validity of their results. Some have suggested using calculus to find the minimum period, while others express difficulty in applying these methods. There is no consensus on the correct approach or the optimal position for drilling the hole.
Some participants mention the need to correct expressions and clarify terms used in the calculations. There is an acknowledgment of the complexity involved in deriving the minimum period, with references to potential errors in previous calculations.
physicsss
A student wants to use a L = 1.0 m stick as a pendulum. She plans to drill a small hole through the meter stick and suspend it from a smooth pin attached to the wall (Fig. 14-35). Where in the meter stick should she drill the hole to obtain the shortest possible period? Answer in number of meters from the upper end
How short an oscillation period can she obtain with a meter stick in this way?
http://www.webassign.net/gianpse3/14-35alt.gif
My guess is 0 meter from the upper end will give the shortest period. Agree?
No. But why guess? Figure it out. What's the period of a physical pendulum?
T=2*pi*sqrt(I/mg(0.5-x))
T=2*pi*sqrt( (1/12mL^2+m(0.5-x)^2) / (12*m*g*(0.5-x) )
Canceling the m
T=2*pi*sqrt( (1/12*L^2+(0.5-x)^2) / (12*g*(0.5-x) )
So if x=0, the period is the smallest...why is this wrong?
OK, but better use (L/2 - x) instead of (0.5 - x). Also, it seems that there's an extraneous 12 in your denominator.
Canceling the m
What makes you think that the period is smallest when x=0?
Because it gives me the smallest T possible when I plug it in...0.50 would give me 0/0
How do you know that? Did you check T for every possible value of x?
The problem is...i don't...and I don't know how to either. :confused:
If you know some calculus, you can find the value of x that minimizes the period by taking a derivative and setting it equal to zero.
OK, I did that and got x=1.5 or -0.5. So -0.5 is the answer? But that doesn't make much sense since they want distance from the upperend of the stick...
No, those answers are not correct. Two suggestions:
(1) Correct your expression as I advised in post #4. Your answer should be in terms of L.
(2) Redo the derivative.
I'm still getting the same answers I got before. Is there any other way to do this since the derivative of 2*pi*sqrt( (L^2+(L/2-x)^2) / (12*g*(L/2-x) ) with respect to x is really difficult for me.
That expression should be:
[tex]T = 2 \pi \sqrt{\frac{L^2/12 + (L/2 - x)^2}{g(L/2 - x)}}[/tex]
This will be a minimum when the expression within the square root is a minimum. So the only thing you need to take the derivative of is this:
[tex]\frac{L^2/12 + (L/2 - x)^2}{(L/2 - x)}[/tex]
Use the quotient (or product) rule. It's not as bad as it looks. :smile:
  • · Replies 24 ·
20K
10K
