Converting binary numbers to floating point format using single-precision IEEE 754
by brian.L
Tags: binary, floating point, mantissa, negative, positve
brian.L
brian.L is offline
#1
Oct18-11, 04:17 PM
P: 7
The problem is how to begin converting 111011.0101 into floating point. I actually did begin looking at the first digit number "1" and identify that it is a negative since is one and zero is positive. Then I try working 111011.0101 separately by splitting 111011 for now and do 0101 after. I am not exactly sure if the decimal between the digits suggest a mantissa, so that is another question I need to be point out on.
Finally, believe I let the following digits 111011 represented by bits. For example: let first digit be 128, let second digit be 64, let third digit be 32, let forth digit be 16, etc.
Then I'm stuck on the part where calculation are suppose to be made?
Note: Here is the question in case I was not clear - Convert the following binary numbers to floating-point format using single-precision IEEE 754 format.
Convert your answer to hexadecimal format.
Convert this 111011.0101 to floating point.
2. Relevant equations
No equations. I'm not sure if there is suppose to be a mantissa somewhere in the digits.
3. The attempt at a solution
Unfinished solution, full calculations has not been completed yet.
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
brian.L
brian.L is offline
#2
Oct18-11, 04:27 PM
P: 7
Help is appreciated :D
Mark44
Mark44 is offline
#3
Oct18-11, 04:30 PM
Mentor
P: 21,069
Quote Quote by brian.L View Post
Since the most-significant bit is 1, the number is considered negative. The rest of the number's bit pattern is 11011.0101, with the first 1 removed.
Your number could be written in a quasi-scientific notation as -11011.0101 X 20. You can move the binary point to the left, simultaneously adjusting the exponent on 2. This is similar to changing 120.3 X 103 to 1.203 X 105.
So -11011.0101 X 20 = -.110110101 X 25.
You're going to have to look at IEEE 754 to see what else you need to do to convert this number to a floating point format.
brian.L
brian.L is offline
#4
Oct18-11, 04:37 PM
P: 7
Quote Quote by Mark44 View Post
Oh, one more question. Is the question going to end up with a different result if there is mantissa?
Mark44
Mark44 is offline
#5
Oct18-11, 04:50 PM
Mentor
P: 21,069
What do you think a mantissa is?
brian.L
brian.L is offline
#6
Oct18-11, 04:58 PM
P: 7
Mantissa replaces any first digit that are negative into zero?
Mark44
Mark44 is offline
#7
Oct18-11, 06:05 PM
Mentor
P: 21,069
I can tell that was totally a guess.
http://en.wikipedia.org/wiki/Significand
And since you don't seem to have much of a clue about the IEEE standard in your thread title, here's a link to a wiki article on it - http://en.wikipedia.org/wiki/IEEE_754
Register to reply
Related Discussions
Single precision floating point Engineering, Comp Sci, & Technology Homework 14
358 in binary single floating point using excess 4 General Engineering 4
floating point format Engineering, Comp Sci, & Technology Homework 1
converting 29 and 0.7 to IEEE single precision floating point Engineering, Comp Sci, & Technology Homework 5
single-precision floating point Introductory Physics Homework 0
