What is the Domain of the f(x)^g(x) Function?
  • Thread starter Thread starter karkas
    Domain Function
The domain of the function h(x) = f(x)^g(x), specifically h(x) = (x^2 - 4)^x, is determined by the conditions that x^2 - 4 must be greater than zero, leading to the intervals x > 2 or x < -2. Additionally, the exponent x introduces further restrictions, as x^x is defined only for positive x and certain negative rational numbers. The consensus is that the domain of x^x is typically (0, ∞), with complications arising when considering negative values.
  • Understanding of function domains and ranges
  • Knowledge of exponentiation rules, particularly with negative bases
  • Familiarity with rational and irrational numbers
  • Basic algebraic manipulation skills
  • Study the properties of exponential functions, focusing on h(x) = (x^2 - 4)^x
  • Learn about the domain of the function x^x and its implications
  • Explore the concept of rational exponents and their restrictions
  • Investigate the behavior of functions with negative bases and their domains
Students studying algebra, particularly those tackling functions and their domains, as well as educators seeking to clarify concepts related to exponentiation and function behavior.
karkas
We have to find the domain range (hope I'm using this right) of some functions, one of them being h(x)=f(x)^g(x), say h(x)=(x^2-4)^(x). I've been looking around and couldn't find the domain range of the x^x function, so I am kinda stuck on this one.
Find the domain of h(x)=(x^2 -4)
Well there's a somewhat obvious requirement (I think), that x^2-4>0 . So we get x>2 or x<-2. Other than that though I don't see any other requirement that stems from the exponent. Maybe that isn't even the case , however. Any suggestions? Thanks!
xx does pose a problem.
When x is a negative number, xq, where q is a rational number, is only defined if the numerator of q is even (and it is applied before applying the denominator), or if the denominator of q is odd.
xr is undefined if r is irrational.
To my knowledge, the usual practice is to consider the domain of xx to be (0, ∞). While you can make a case for including a subset of the negative rational numbers, to do so puts a lot of holes in the domain for x < 0 .
  • · Replies 23 ·
