Finding Taylor Polynomial for f(x) = (1+x)^{2/3}
  • Context: Graduate
  • Thread starter Thread starter 3.14159265358979
    Polynomial Taylor
The discussion centers around finding the Taylor polynomial for the function f(x) = (1+x)^{2/3} expanded about a = 0. Participants are addressing various aspects of the problem, including the calculation of derivatives, the Lagrange remainder formula, and estimating errors in polynomial approximations.
  • Homework-related
  • One participant initially proposes the Taylor polynomial T_2(x) as 1 + (1/3)x - (1/9)x^{2}, but later corrects it to 1 + (2/3)x - (1/9)x^{2}.
  • Another participant questions the correctness of the derivatives f'(x) and f''(x) used in the polynomial.
  • A participant provides the Lagrange remainder formula but expresses uncertainty about finding the last term in the sequence and the error term.
  • Clarifications are made regarding the use of the Lagrange remainder formula, specifically that it represents the error between the function and its Taylor polynomial.
  • Discussion includes the need to compute the third derivative of the function to establish an upper bound for the error when x > 0.
Participants do not reach a consensus on the correct form of the Taylor polynomial or the derivatives involved. There is ongoing uncertainty regarding the calculation of the Lagrange remainder and the estimation of the error term.
Participants express confusion over the application of the Lagrange remainder formula and the specific derivatives required for the Taylor polynomial. There are also ambiguities in the notation and intervals used in the discussion.
3.14159265358979
1. Let f(x) = (1+x)^{2/3}
(a) find the taylor polynomial T_2(x) of f expanded about a = 0.
i got 1 + (1/3)x - (1/9)x^{2}
For the rest, i have no idea how to do...any help would be greatly appreciated.
(b) For the givven f write the lagrange remainder formula for the error term f(x) - T_2(x).
(c) Show that when x>0 the error f(x)-T_2(x) is at most (5/18)x^{3}. and
(d) Write a fraction that estimates (1.2)^{1/3}, and show that the error in your estimate is at most 1/2025.
Thanks for any help you can provide!
What did you get for f'(x) and f''(x)? Your polynomial is a bit off.
Do you know what the Lagrange remainder is? If not look it up and post again with what about it is troubling you.
sorry, T_2(x) is suppose to be 1 + (2/3)x - (1/9)x^{2}
i believe the lagrange remainder is: f^{n+1}(p) * (x-a)^{n+1}
(n+1)!
where p is between (a,n).
The problem is, i don't know how to find the last term in the sequence or the error (which i believe is also called the lagrange remainder, right?) thanks for your reply!
sorry, the lagrange remainder is suppose to be
(n+1)!
The remainder term you have gives f(x)-T_n(x), the difference between f and it's taylor polynomial of degree n, also known as the error between the Taylor polynomial and the function it's trying to approximate. In your case n=2 and a=0, so you just put these values into the remainder formula you have and work out the 2+1=3rd derivative of your function.
The p point comes from the mean-value theorem and you don't actually know what it is, just the interval it's on. You said it's on (a,n), did you mean (a,x), for x>a? You can use this to give an upper bound for the error when x>0 by noticing that the third derivative of this function is bounded here.
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 16 ·
