Static Equilibrium-Balancing Forces and Torque
The discussion focuses on calculating the torque applied by a teeter-totter with two children of masses 45 kg and 30 kg. The teeter-totter is 4.0 m long and pivots at its center. The torque formula used is T = r x F sin(theta), where T is torque, r is the distance from the pivot, and F is the force due to gravity. The example provided calculates the torque for the 30 kg child as 147 N·m, using a distance of 1.0 m from the pivot, which requires clarification regarding the positioning of the other child.
  • Understanding of torque and its calculation using the formula T = r x F sin(theta)
  • Knowledge of gravitational force, specifically 9.8 N/kg
  • Familiarity with the concept of static equilibrium in physics
  • Basic understanding of mass and distance in relation to pivot points
  • Study the principles of static equilibrium in physics
  • Learn more about torque calculations in different scenarios
  • Explore the effects of varying mass and distance on torque
  • Investigate the implications of pivot points in mechanical systems
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of torque and equilibrium in practical applications.
phizics09
Two children of masses 45 kg and 30 kg are playing on a teeter-totter of length 4.0m and mass 30.0kg, pivoted at its centre. The heavier child sits 1.75 m from the centre of the teeter-totter that is 0.50 m from the ground. a) What torque does the teeter-totter apply to each of its sides? With this knowledge, how could you simplify any further calculations.
T=r x Fsin(theta)
The example says:
T=rF sin (theta)
T=(1.0 m)(30.0 kg)(9.8 N/kg)
t-t  147 N·m
I don't understand where the one metre is coming from.
Can anyone help me?
The question is too vague to answer. It doesn't specify the coordinates of the other child.
  • · Replies 21 ·
13K
