How do I find the formula for the hydrate?
  • Thread starter Thread starter Dooh
The problem involves determining the formula for a hydrate of magnesium sulfite (MgSO3) based on mass measurements before and after heating. The original poster seeks clarification on what constitutes a hydrate.
  • Participants discuss the definition of hydrates and the significance of water molecules in the chemical structure. Some express uncertainty about how to calculate the ratio of moles of MgSO3 to moles of water. Others attempt to derive the mass of water lost during heating and consider how to convert these masses into moles for further analysis.
The discussion is ongoing, with participants exploring different interpretations of the problem and sharing insights about the relationship between mass and moles. Some guidance has been offered regarding the conversion of mass to moles, but no consensus has been reached on the final formula for the hydrate.
There is mention of a lack of prior instruction on this topic, which may affect participants' confidence in approaching the problem. The original poster and others are grappling with the concepts of hydration and mole ratios.
Dooh
The problem is:
A hydrated sample of MgSO_3 weighs 1.500g before heating and 0.737g after heating. What is the formula for the hydrate?
what exactly is a hydrate?
From what I can remember, a hydrated compound is a chemical compound that absorbs water molecules into its chemical structure in a very definite way. Hence the term, "hydrated" compound. The corresponding "dry" compound into which no water molecules have been absorbed is termed the "anhydrous" compound, and it usually has different visual appearance and properties.
Sometimes hydration reactions occur spontaneously (a compound will slowly absorb or release water from or into the atmosphere). However, hydration is not the same thing as a substance simply becoming 'wet' i.e. a substance is not necessarily 'hydrated' just because you dumped a bunch of water on it. As I said before, a chemical reaction must occur in which the water molecules are incorporated into the lattice structure of the compound in very specific proportions. For example, if a hydrated compound has five water molecules per formula unit (I just gave five as an example..you have to look up how many it is for this compound), then the chemical formula denoting this structure would be:
[tex]\text{MgSO}_3 \bullet 5\text{H}_{2}\text{O}[/tex]
There are five water molecules for every pair of Mg2+ and SO32- ions.
If you are wondering what the nature of the chemical bond between these water molcules and the compound in question is, then I'm afraid I don't know.
im assuming the problem is asking me to figure out what the water molecule per unit is then? our teacher didnt teach us about these things yet >.< so i have no idea on how to do this problem
OOOOOOOOO this just occurred to me as i waslooking at the problem
since its 1.500g when its hydrated, and after heating it, it becomes .737g. that means all the weight that was lost is H20 right?
from that i know the mass of H20 in that compound, then um..now what?
A chemical formula (what the question is asking for) includes mole ratios between parts of the molecule. How can you find the ratio of moles of [itex]MgSO_{3}[/itex] to moles of water using the masses?
Dooh said:
The problem is:
How many moles of MgSO3 are in 0.737g? I get an answer around 0.0070614 moles. I'll store that as "A" in my calculator.
Take the change of masses to have the mass of water.
1.5 - 0.737 = 0.763g water. That's about 0.04234 moles of water. Store that value as "B".
Now take a ratio between the water and the MgSO3.
B/A = 5.99622 ~= 6
MgSO3 * 6H2O
Excellent! You might not have been taught this stuff, but you figured out what the problem was asking, and what the key concepts and info are that you need to solve it.
Think about it this way...you have a question that's asking about the amount of a substance that forms part of a compound, in terms of numbers of molecules, as opposed to mass. So what is a conveniently large number for expressing numbers of molecules? The mole. Convert everything into amounts in moles, instead of mass in grams, that way you can directly compare the relative amounts of various substances making up the compound. Try that, and let me know how it goes...
13K
10K
