Will running during rainfall makes you more wet?
  • Context: High School
  • Thread starter Thread starter RobinSky
    Running
The discussion revolves around whether running in the rain makes a person wetter compared to walking. Participants explore various factors influencing this, such as the angle of the rain, the speed of the person, and the characteristics of the raindrops. The conversation includes theoretical considerations and personal experiences related to the physics of rain and motion.
  • Some participants suggest that running may lead to getting wetter due to running into raindrops falling in front of the person, while avoiding those falling directly overhead.
  • Others argue that running could keep the head drier since fewer raindrops would fall on top of it compared to walking.
  • It is noted that the speed of raindrops is generally constant, but their terminal velocity can vary based on size.
  • A participant mentions that if the rain is angled in the same direction as the person's motion, running could result in getting less wet.
  • Some contributions reference the Mythbusters show, indicating that running may increase wetness under certain conditions, particularly in heavy rain.
  • There are discussions about the geometry of the body and how it interacts with falling rain, suggesting that the shape and orientation of the body could affect wetness.
  • One participant expresses confusion over the conflicting views, particularly regarding straight-down rain and the impact of running versus walking.
Participants do not reach a consensus on whether running makes one wetter or drier in the rain. Multiple competing views remain, with some convinced that running increases wetness while others argue the opposite, particularly under different conditions.
The discussion includes assumptions about the constancy of rainfall and the effects of different speeds and angles of rain. Some participants acknowledge that their conclusions depend on specific conditions and definitions of "wet." There are also references to external sources and previous discussions that may provide additional context.
RobinSky
(sorry for the typo in the title)
I have heard both yes and no when it comes to this. But now it's time to ask you guys who probably really can put this to test.
Certain factors is probably like the angle of the falling rain relative to your motion, right? And the volume per cubic meter of rain? The speed of the person walking/running? The speed of the falling rain (or is the velocity v always the same for rain?)? The density of the water droplets?
I think you understand, what's the truth?
Thanks in advance!
I depends how far the shelter is and how long the rainstorm lasts. If also depends on your definition of "wet". If your head is wet, it usually means more to you than when your body is wet. However, running will always make you wetter faster, if you are not getting to shelter before the rainstorm is finished.
Well, you will get wet as you will run into raindrops falling in front of you (already past the height of the top of your head), but then you will avoid raindrops about to fall on top of you (on your head).
Regardless of if you run or walk you should walk/run into roughly the same amount of raindrops, but if you run you should get fewer raindrops on your head.
In conclusion, running will keep you (your head) drier.
In answer to one of your sub-questions: raindrops will tend to fall at a similar speed (their terminal velocity), this does depend, though, on their size, but the outcome will be the same for every type of rain; running = drier head.
If the rain is angled considerably in the same direction as you are headed then running will definitely keep you much drier than walking as you'll be moving with it (less difference between your horizontal vectors, ergo fewer collisions).
Lastly, I think raindrops' density tends to stay the same (that of normal water).
All this is assuming the rate of rainfall remains constant and ceteris paribus etc. etc. throughout the rainy passage.
Hope it helped!
PhysicsChode said:
Well, you will get more wet as you will run into raindrops falling in front of you (already past the height of the top of your head), but then you will avoid raindrops about to fall on top of you (on your head).
Hope it helped!
That might work if you are a sphere. but you are not.
Care to elaborate?
A nice way to visualize this is the reference frame of the falling raindrops: The drops are a static field, and the person is moving though them and collecting them, until he reaches a boundary. The horizontal boundary is the begin of a shelter. The vertical boundary is the end of the rain shower. The optimal behavior depends on how far away he is from each boundary, and the geometry that you assume for the body.
If the rain is going to last to infinity, you should obviously run.
I think Mythbusters did a show on this.
I was just about to say that. They did. They put "spongy" suits on and ran through different rates of rain. Running does make you more wet if its raining really hard because you allow for a lot more surface area since youre hitting the rain with the whole front of your body. If you walk, mostly the shoulders get saturated.
Here's a thread that dealt extensively with your question
https://www.physicsforums.com/showthread.php?t=204749"
If rain is falling straight down, your speed changes the distribution of wetness but not how wet you get. Unless you run so fast that you bend forward, in which case you sweep out less volume and get less wet.
Thanks for the replies guys. From reading the other post in this forum I get the impression of it doesn't really matter? Some people are truly convinced arguing that you will get more wet if you run, some the opposite.
And according to the discussed formula in the beginning of the post it looked like you will get less wet if you run.
If rain were falling in angle towards your relative motion it seems to makes you more wet, which I also find obvious.
But the question is, rain falling straight down? More wet by running, yes or no? I've gotten more confused now :D
Even if you have certain horizontal velocity the rain will appear as if falling through an angle. this is because you tend to move towards the raindrops just in front of you.
  • · Replies 46 ·
11K
  • · Replies 55 ·
13K
  • · Replies 32 ·
  • · Replies 24 ·
12K
