Should I take the absolute value of a negative t-test statistic?
The discussion centers on the handling of negative t-test statistics in one-sided tests. When the sample mean is less than the mean under the null hypothesis (H_0), a negative t-test statistic is obtained. It is established that one should not simply take the absolute value of the t-statistic; instead, the critical value from the t-table should be considered. Specifically, for a one-sided test with a less-than alternative, the rejection criterion involves comparing the t-value directly to the negative of the critical value.
  • Understanding of one-sided t-tests
  • Familiarity with null hypothesis (H_0) concepts
  • Knowledge of t-distribution tables
  • Basic statistical hypothesis testing principles
  • Study the implications of one-sided versus two-sided t-tests
  • Learn how to interpret critical values from t-distribution tables
  • Explore common pitfalls in hypothesis testing
  • Review statistical software options for performing t-tests, such as R or Python's SciPy library
Statisticians, data analysts, and researchers involved in hypothesis testing who need clarity on the treatment of negative t-test statistics in one-sided tests.
lavster
I have calculated the one sided t-test statistic and am getting a negative value as the sample mean is less than the mean under H_0. there are no negative t values in the table - do i take the absolute value of this?
thanks
Take the negative of the critical value in the table and reject if your t-value is less than this.
I'm presuming you're doing a one-sided test on (<). In this instance you could take the absolute value and reject when t is greater than, but you can probably see how always taking the absolute value can go wrong for a one-sided test?
  • · Replies 23 ·
  • · Replies 43 ·
  • · Replies 24 ·
  • · Replies 30 ·
