How Far Will an Object Land When Released from Twice the Height?
  • Thread starter Thread starter krypt0nite
    Energy Work
The problem discusses the trajectory of an object released from a height of 2h on a frictionless track. By applying the conservation of mechanical energy, it is established that the horizontal distance covered when released from 2h is √2 times the distance d covered when released from height h. The calculations involve determining the velocity at the bottom of the track using the equation v = √(2gh) and the time of fall using t = √(2S/g), leading to the final formula for the new distance as √2 * d.
  • Understanding of mechanical energy conservation principles
  • Familiarity with kinematic equations for projectile motion
  • Knowledge of basic physics concepts such as potential and kinetic energy
  • Ability to manipulate algebraic equations and square roots
  • Study the principles of conservation of energy in physics
  • Learn about kinematic equations and their applications in projectile motion
  • Explore the effects of varying heights on projectile trajectories
  • Investigate real-world applications of frictionless motion in engineering
Students of physics, educators teaching mechanics, and anyone interested in understanding projectile motion and energy conservation principles.
krypt0nite
Can someone help me explain this problem to me? I try a bunch of things and I dont' really know how to get the answer.
An object starts from rest and slides down a frictionless track as shown. It leaves the track horizontally, striking the ground at a distance d as shown. The same object is now released from twice the height, 2h. How far away will it land?
Diagram of Problem
Somehow... the answer is squareroot 2*d
A very simple problem. No need to worry at all!
This problem uses the simple fact that mechanical energy is conserved.
Since it is a frictionless track, the potential energy of the ball on top should
be equal to the kinetic energy when it reaches the bottom of the track.
If m be the mass of the ball and
v be the velocity acquired by the ball at the bottom
m*g*h = 0.5*m*(v^2)
which gives us v = square root(2*g*h)
Now when it leaves the track, its vertical velocity, u, is zero.
Horizontal velocity is v
Let S be the height of the bottom of the track from the ground.
let us calculate the time taken for it to fall from the bottom of the track to the ground.
Remember this time will not depend on the height from which the ball is rolled down.
so
S = (u*t) + 0.5*g*(t^2)
S = 0.5 * g * (t^2)
since u = 0
that gives us
t = square root(2S / g)
now the distance covered horizontally is veloctity*time.
(because there is no acceleration acting in the horizontal direction)
that is d = v*t
d = square root(2gh) * square root(2S / g)
now if the ball is released from 2h, replace the h in the above equation by 2h
that is
new distance = square root(2g*2h) * square root(2S / g)
= squareroot(2) * square root(2gh) * square root(2S / g)
which is nothing but
square root (2) * d
Sure, I'd be happy to help explain this problem to you. Let's break it down step by step.
First, we have an object that starts from rest, meaning it has no initial velocity, and slides down a frictionless track. This means that there is no force slowing it down or causing it to speed up, so it will maintain a constant velocity as it slides down the track.
Next, we see that the object leaves the track horizontally and strikes the ground at a distance d. This means that the object's horizontal velocity remains the same as it leaves the track and travels through the air until it lands on the ground.
Now, we introduce a new variable, 2h, which represents the object being released from twice the height as before. Since the object is being released from a greater height, it will have a greater potential energy. This potential energy will be converted into kinetic energy as the object slides down the track and leaves it horizontally.
Finally, we are asked to find the distance that the object will land when released from 2h. To solve this, we can use the conservation of energy principle, which states that energy cannot be created or destroyed, only transferred from one form to another. In this case, the potential energy at the top of the track is equal to the kinetic energy at the bottom of the track.
We can set up an equation using this principle:
mgh (potential energy at 2h) = 1/2 * mv^2 (kinetic energy at d)
Since the mass of the object and the acceleration due to gravity (g) are constant, we can cancel them out. This leaves us with:
h = 1/2 * v^2
Now, we can solve for v (the object's velocity at d) by taking the square root of both sides:
v = √2h
Since the horizontal velocity remains constant, we can use this value for v to find the horizontal distance traveled, d.
d = v * t (where t is the time it takes for the object to travel from the track to the ground)
Since we are dealing with a horizontal distance, we can use the formula d = v * t = √2h * t.
Now, we need to find the value of t. We can use the formula d = 1/2 * g * t^2 (where g is the acceleration due to gravity and t is the time it takes for
18K
