Work Energy Problem Package released to Spring
The discussion focuses on a physics problem involving a 2.00 kg package released on a 53.1-degree incline, approaching a spring with a force constant of 120 N/m. The problem requires calculations for the package's speed before reaching the spring, maximum spring compression, and rebound distance. Key equations utilized include the conservation of energy and the work-energy principle, with specific attention to the frictional forces calculated using the normal force. The initial speed calculated was 6.86 m/s, but the friction force was incorrectly computed, necessitating a correction using the normal force.
  • Understanding of conservation of energy principles
  • Knowledge of friction coefficients and their application
  • Familiarity with inclined plane mechanics
  • Ability to calculate normal force in physics problems
  • Review the calculation of friction forces using normal force in inclined planes
  • Study the conservation of energy in mechanical systems
  • Learn about spring dynamics and energy storage
  • Explore kinematics of motion on inclined surfaces
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to energy conservation and friction on inclines.
XwyhyX
A 2.00 kg package is released on a 53.1 degree incline, 4.00m from a long spring with force constant 120 N/m that is attached at the bottom of the incline. The coefficients of friction between the package and the incline are [itex]u{s}[/itex] = 0.40 and [itex]u{k}[/itex] = 0.20. The mass of the spring is negligible. (a) What is the speed of the package before it reaches the spring? (b) What is the maximum compression of the spring? (c) The package rebounds back up the incline. How close does it get to its initial position?
m = 2.00kg
θ = 53.1°
k= 120 N/m
L1= 4m
[itex]u_{s}[/itex] = 0.40
[itex]u_{k}[/itex] = 0.20
http://img819.imageshack.us/img819/1936/38218769.png
Uploaded with ImageShack.us
Conservation of Energy
[itex]K_{1}[/itex] + [itex]U_{1}[/itex] + [itex]W_{o}[/itex] = [itex]K_{2}[/itex] + [itex]U_{2}[/itex]
I know that to solve for a I will only consider the distance it has covered before touching the spring which is 4.0 m
So
[itex]K_{1}[/itex] = 0 because it is released from rest
[itex]U_{1}[/itex] = mgy = (2)(9.8)Lsinθ
[itex]W_{o}[/itex] = [itex]W_{f}[/itex] = -fL1 = -μmgL1 =- (0.2)(2)(9.8)(4)
[itex]K_{2}[/itex] = [itex]1/2[/itex]m[itex]v^{2}[/itex] = [itex]1/2[/itex](2)[itex]v^{2}[/itex]
[itex]U_{2}[/itex] = 0 I'm not sure with this but i assume that at this point it's the reference point
Solving this
v = [itex]\sqrt{(2)(9.8)(4sin53.1°) - (0.2)(2)(9.8)(4)}[/itex]
v = 6.86m/s
Is this correct? I can't continue because I'm not sure. I'll continue solving the b and c after I clarify this part. Thanks!
You have the equations correct but you did not calculate the friction force correctly. You used umg when it should be uN, where N = ?
Oh N = mgcosθ. My bad, i'll have to correct that. Thanks!
  • · Replies 58 ·
  • · Replies 17 ·
