How do I solve for X in the equation X^(1/3) - 4(X^[-1/3]) = 3?
  • Thread starter Thread starter Doubell
The discussion revolves around solving the equation X^(1/3) - 4(X^[-1/3]) = 3, which involves concepts related to algebra and manipulation of equations involving cube roots.
  • Exploratory, Assumption checking, Mixed
  • Participants discuss substituting X^(1/3) with Y to simplify the equation. There are attempts to factor the resulting quadratic equation and check the validity of the solutions obtained. Some participants express a desire to explore different approaches to the problem.
The discussion includes verification of the proposed solutions by substituting them back into the original equation. There is acknowledgment of the potential for extraneous solutions, but some participants suggest that the method used does not introduce such issues in this case. The conversation remains open to alternative methods.
One participant notes the importance of checking for extraneous solutions after manipulating the equation, while another emphasizes that the nature of cube roots allows for real solutions without introducing false ones.
Doubell
SOLVE FOR X IN THE EQUATION:
I LET X^1/3 = Y
THEN THE ORIGINAL EQUATION BECOMES
Y - 4* 1/Y = 3
MULTIPLYING THE ENTIRE EQUATION BY Y RESULTS IN
Y^2 - 4 = 3Y
THEREFORE Y^2 -3Y - 4 = 0
THE ROOTS OF THE EQUATION ARE DEFINED BY (Y+1) (Y-4)
THEREFORE Y = -1 OR Y = 4
AND SINCE Y = X^1/3 THEN
X^1/3 = -1 OR X^1/3 = 4
THEREFORE [X^1/3]^3 = [-1]^3 SO X = -1 AND [X^1/3]^3 = [4]^3 SO X = 64
HENCE THE SOLUTIONS OF X ARE -1 AND 64.
STOP SHOUTING! (Please stop typing in all caps.)
Doubell said:
I LET X^1/3 = Y
Y - 4* 1/Y = 3
Y^2 - 4 = 3Y
You're not done yet. Now you have to plug each solution into the original equation and check. By multiplying both sides by Y earlier you may have introduced an extraneous solution.
ok for x= -1 ; (-1)^1/3 -4/(-1)^1/3 = 3 THIS IMPLIES -1 (-4)/-1 = -1 +4 = 3
AND FOR X = 64 ; (64^1/3) - 4/(64^1/3) = 3
WHICH IS 4 - 4/4 = 4-1 = 3 THE SOLUTIONS ARE TRUE FOR BOTH VALUES OF X. I WOULD LIKE TO SEE A DIFFERENT APPROACH THOUGH.
I don't think he heard you !
This really is the cleanest approach to solving this equation. You don't really want to "cube" both sides of the original equation, as this will just create more terms with various powers of the cube-root of x to be wrestled with.
While eumyang's suggestion to check for extraneous solutions is always in order, the danger doesn't really arise here. Since one can always take cube-roots of real numbers (and cube-root is "one-to-one"), there will not be a value of Y which does not correspond to a real value of x . Multiplying the transformed equation through by Y is also not an issue here, since we can see easily enough that Y = x1/3 = 0 is not a solution to the equation, so we are not falsely introducing a solution or making the equation into potential nonsense.
i apologize for the shouting.
  • · Replies 17 ·
