Cooling of Contra- rotating Motor
The discussion revolves around the cooling mechanisms for contra-rotating motors and generators, specifically addressing the challenges of heat removal from copper coils due to electrical resistance. Participants explore the feasibility of liquid cooling versus air cooling in various environmental conditions and applications.
  • Experimental/applied
  • One participant questions how oil can be circulated around the heating copper coil in a contra-rotating motor, given that both the stator and rotor are rotating.
  • Another participant expresses skepticism about the necessity of contra-rotating motors and suggests that counter-weights could address torque control issues.
  • A participant mentions the existence of contra-rotating generators and acknowledges their application in experimental designs.
  • Some participants note that contra-rotating designs can mitigate gyroscopic effects and may be used in military jet engines, but they find limited examples of large-scale contra-rotating electric motors or generators.
  • One participant asserts that certain experimental wind turbines with contra-rotating generators require liquid cooling, although they struggle to identify specific cooling mechanisms.
  • Another participant questions the need for liquid cooling when air cooling is available, citing existing air-cooled wind turbine designs and expressing concerns about the practicality of using liquid coolant in large rotating components.
  • A later reply highlights the challenges of cooling in extreme environments, such as offshore turbines or hot desert conditions, while reiterating the search for liquid cooling solutions.
  • One participant critiques the inconsistency in the discussion regarding the power ratings and environmental contexts of the motors and generators being referenced.
Participants express differing views on the necessity and practicality of liquid cooling versus air cooling for contra-rotating motors and generators. There is no consensus on the best approach or specific solutions for the cooling problem presented.
Participants reference various power ratings and environmental conditions, which may affect the applicability of cooling solutions. The discussion lacks clarity on the specific parameters of the cooling problem being addressed.
bhaazee
For contra-rotating motor, the external rotating element is a cylinder that carries copper coil and on account of electrical resistance, the coil is getting heated. The generated heat can be removed only by circulating oil around the coil through cavities/vents available inside the cylinder that holds the copper coil. However, as both the stator and rotor are rotating how can the oil be carried into and out of the cavities? any Idea?
Regards.
:confused:
I've never heard of a contra-rotating motor, and can't for the life of me think of any reason to build one. If torque control is a problem, that's what counter-weights are for.
k fine. You can even assume this for a generator and contra-rotating generators are available.
Contra rotation cancels the gyroscopic effects. Some military jet engines have contra rotating shafts for that reason. It can also save a set of stator vanes between the contra-rotating turbines, which is a nice bonus.
But the only contra-rotating electric motors and generators that I found on Google are small motors intended for model aircraft, or "experimental" generator designs for wind turbines - nothing big enough to need oil cooling.
The so called experimental wind turbines with contra-rotating generators (with dual propellers) are 100 KW models as I believe. This obviously needed liquid cooling process. But unable to find the cooling mechanism.
Why would you want to use liquid cooling, when you have an unlimited supply of cooling AIR available? There are commercial air-cooled wind turbine designs up to 1.5MW. Even above that power, the idea of immersing large rotating components in liquid coolant doesn't seem like a good idea, except for oil-filled gearboxes where the oil has another function apart from cooling.
Consider a 2 MW wind turbine.Assuming its an Off-shore turbine, heat removal by air cooling will probably not be recommended. Assume a wind turbine in Sahara (50°C) Probably will make no sense to cool by air. Just an example.
Back to my query, I am trying in particular for some liquid cooling solutions.
May be some liquid cooling solutions are already available for my defined problem. However, unfortunately I am not able to catch those specific technical words to google it.
Sorry, but if you are jumping between motor and a generator, 100kW and 2MW power, and from offshore to a hot desert envioronment, I don't have any idea what your "defined" problem really is, except that you seem insistent on liquid cooling it.
  • · Replies 24 ·
10K
  • · Replies 23 ·
