Creating a New Model for Friction Based on Experimental Results
  • Context: Graduate
  • Thread starter Thread starter Brewer
    Friction Modelling
The discussion revolves around the development of a new model for friction based on experimental results involving the sliding and toppling of blocks at varying angles. Participants explore the limitations of the Coulomb model of friction and consider factors affecting the coefficient of friction in their experiments.
  • One participant seeks guidance on creating a new model for friction, noting that their experimental results do not align with the Coulomb model.
  • Another participant suggests that variations in the coefficient of friction could be due to changes in the surfaces involved, such as roughness or the presence of lubricants.
  • A participant mentions that the coefficient of friction can be derived from the tangent of the angle, as indicated in their textbook, but expresses confusion about how to develop a new model that fits their experimental data.
  • One participant emphasizes the complexity of friction, highlighting that it is highly dependent on the specific characteristics of the surfaces in contact, which can vary significantly.
Participants express differing views on the factors influencing friction and the adequacy of the Coulomb model. There is no consensus on how to develop a new model that accurately reflects the experimental results.
Participants note the potential impact of surface characteristics, environmental factors, and the nature of the materials on friction, suggesting that these variables complicate the modeling process.
Brewer
What would be the best way to come up with a new model for friction based on my experimental results?
I have been finding the angle at which a block slides, or topples when the angle it is inclined at is increased. This has been done with blocks that are of different heights (towers of building blocks), and the experimental results don't fit the model for friction.
The initial model is coulombs model
(i.e. F=uR)
The model has been used to work out the angle for sliding and toppling with different amounts of blocks, so I decided to take logs of both the number of blocks and the angle, but then couldn't see how to put this back into a new model.
Any ideas how to look at a new model based my experimental results would be appreciated.
Thanks
Friction depends on the quality (e.g. roughness) of the interacting surfaces.
If the coefficient of friction does not match the accepted values, and there is always some variation, then perhaps the coefficients are actually different, or one or both surfaces are changing.
If the friction is increasing then one or both of the surfaces may be becoming rougher. If friction is decreasing, then one of both surface may be becoming smoother.
Also, if a lubricant is inadvertently added, then one is affecting the interaction of the two surfaces. Lubricant reduce the shear forces betweent two surfaces.
That kind of makes sense. I have found the coefficient of friction as being the tangent of the angle. My textbook tells me that. For use in my original model I had to use a value for the coeffiecient (henceforth called u). I took this u to be an average value that I had worked out for my experiment.
However the model suggests that u should not change depending on the size of the mass as these cancel out
because F = mg sin x, and R = mg cos x where x is the angle
therefore F = uR
mg sin x = u * mg cos x
which cancels to
tan x = u
Its just bugging me about how to create a new model to fit the experimental results that I have!
At least part of the problem is the surface that you happen to be experimenting with.
Friction is poorly undertood -- because it is SO dependent upon the precise nature of the surface which is rarely ideal,
Even for a rough surface it only take 3 points to theoretically to hold them apart -- BUT if you move it , it will be a different 3 points -- with their own properties.
At any particular point you deal with the exact atomic surface , this may include roughness , the environmental gas , surface impurities like skin oil - you name it it is probably there -- so averages and statistics are in order -- do not expect precise results .
Note that if the surfaces were totally clean and flat then they would stick and you could not get them apart.
Ray
  • · Replies 18 ·
  • · Replies 0 ·
  • · Replies 45 ·
  • · Replies 0 ·
  • · Replies 26 ·
