Negative value when calculating the distance
In summary, the distance required for a 1000 kg car traveling at 25 m/s to stop with locked wheels and a coefficient of friction of 0.95 is 33.6 m, with a negative acceleration of -µg. The negative sign indicates that the car is decelerating.
Anna55
A 1000 kg car traveling rightward at 25 m/s slams on the breaks and skids to a stop (with locked wheels). Find the distance required to stop it. Coefficient of friction between the tires and the road is 0.95. Let g=9.8 m/s^2
Solution:
2aΔx=vf2- vo2
a=µg
2 µg Δx=vf2- vo2
vf=0
2 µg Δx=- vo2
Δx=- vo2/2 µg
Δx=-252/(2×0.95×9.8)
Δx=-33.6 m
The answer became -33.6 m. Why is the value negative? The correct answer is 33.6. Thank you in advance!
The acceleration is negative, a=-µg.
ehild
If I have understood this correctly, the solution should be this:
2aΔx=vf2- vo2
a=-µg
2 -µg Δx=vf2- vo2
vf=0
2 -µg Δx=- vo2
Δx=- vo2/2 -µg
Δx=-252/(2×-0.95×9.8)
Δx=33.6 m
To denote power, use "^". Use parentheses when multiplying with a negative number. 2 -µg Δx means subtraction. Correctly: 2(-µg)Δx or -2µg Δx. And 25^2=625.
Written correctly your derivation, it looks :
2aΔx=vf^2- vo^2
a=-µg
2 (-µg) Δx=vf^2- vo^2
vf=0
2 (-µg)Δx=- vo^2
Δx=- vo^2/(-2µg)
Δx=-625/(2×(-0.95)×9.8)
Δx=33.6 m
ehild
Thank you very much ehild! I understand now.
1. What does a negative value for distance mean?
A negative value for distance means that the two points being measured are in opposite directions from each other. It indicates that the distance between the two points is less than zero, which is not possible in traditional distance measurements.
2. Why do negative values sometimes occur when calculating distance?
Negative values can occur when calculating distance due to a variety of factors such as incorrect input values, miscalculations, or using a coordinate system with a different origin point. It is important to check your calculations and inputs carefully to ensure accurate results.
3. Can negative values for distance be used in real-world applications?
No, negative values for distance cannot be used in real-world applications as they do not accurately represent physical distances. They may be used in mathematical or theoretical contexts, but in practical applications, negative distances are not meaningful.
4. How do I correct a negative value for distance?
To correct a negative value for distance, you can check your inputs and calculations for errors. If the negative value is a result of using a different coordinate system, you can convert it to a system with a different origin point. Alternatively, you can take the absolute value of the negative distance to get a positive value.
5. Is it possible to have negative distances in certain situations?
In some cases, negative distances may be used in abstract or mathematical contexts, but in real-world applications, they are not meaningful. It is important to carefully consider the context and purpose of the distance measurement to determine if a negative value is appropriate or not.
20K
