| New Reply |
Series capacitance added to parallel resonant tank changing the resonant freq? |
Share Thread | Thread Tools |
| Oct23-11, 03:23 AM | #1 |
HI all,
A parallel tank circuit at resonance has a theoretical infinite impedance. However due to the resistance of L and C some power is dissipated so a small current will flow from the source. If a parallel tank circuit is oscillated at it's resonant frequency and a capacitor (C2) is added in series the circuit's impedance will change. But will it change the resonant frequency? ![]() -----NEXT---- If the circuit has a diode (D1) in it the parallel tank will still resonante since the resonance takes place between the parallel L and C. So if a capacitor (C2) is added to the circuit will the resonant frequency change? ![]() Thanks in advance! |
| Oct23-11, 10:19 AM | #2 |
Recognitions:
Putting a capacitor in series with the parallel tuned circuit will not change the parallel resonant frequency, but it will introduce a new series resonance at a lower frequency.
To see an effect, though, you would need to add a suitable resistor in series with the signal source. I simulated it with 5000 ohms in series with your circuit. Both capacitors were 64 pF and the inductor was 16 µH. Parallel resonance was at 5 MHz and series resonance was at 3.5 MHz Adding a diode will cause C2 to charge up and reverse bias the diode for most of the input waveform. So there will be little or no output. |
| New Reply |
| Thread Tools | |
Similar Threads for: Series capacitance added to parallel resonant tank changing the resonant freq?
| Why am I getting an amplitude modulated AC signal across a resonant tank cirucit? | Electrical Engineering | 4 | ||
| Self Resonant Freq of Spiral Inductor | General Physics | 4 | ||
| why does the resonant freq decrease as damping increase in an oscillating system? | Introductory Physics Homework | 8 | ||
| Changing Resonant Frequency of Gas? | Mechanical Engineering | 9 | ||
