Some questions about the Lambert W function
  • Context: Graduate
  • Thread starter Thread starter dimension10
    Function
The discussion centers on the properties and limits of the Lambert W function, specifically addressing the limit as \( x \) approaches negative infinity. It is established that the limit does not exist for the real branches \( W_{0}(x) \) and \( W_{-1}(x) \), as the function does not dip to negative infinity. The complex branches may exhibit different behavior. Additionally, the inverse function of \( x^x \) can be expressed using the Lambert W function by rewriting it as \( x = \exp[y \ln y] \) and applying logarithmic transformations.
  • Understanding of the Lambert W function and its branches, specifically \( W_{0}(x) \) and \( W_{-1}(x) \)
  • Familiarity with limits and continuity in mathematical functions
  • Basic knowledge of logarithmic and exponential functions
  • Concept of complex analysis, particularly regarding branches of functions
  • Research the properties and applications of the Lambert W function in mathematical analysis
  • Explore the behavior of complex branches of the Lambert W function
  • Learn about the implications of limits in real and complex functions
  • Study the use of the Lambert W function in solving equations involving exponentials and logarithms
Mathematicians, students studying advanced calculus, and anyone interested in the applications of the Lambert W function in mathematical modeling and analysis.
dimension10
I was wondering, what would be the solution for [tex]\lim_{x \rightarrow -\infty} W(x)[/tex] where W(x) is the Lambert-W function.
Wolfram|Alpha gives the result [tex]\infty[/tex] but the graph certainly does not imply this (In fact,[tex]\lim_{x\rightarrow \infty} x\,\exp(x)=\infty[/tex]) I only graphed it it between -10 and 10 and behind -1.5 or so, the graph goes straight down so you can't even see the function beyond -1.75 or so. Does the function make a sharp turn somewhere else behind? Is the function even continuous?
Also,
[tex]\lim_{\omega \rightarrow -\infty} \omega \,\exp(\omega)=0[/tex] and [tex]\lim_{\omega\rightarrow 0} \omega\,\exp(\omega)=0[/tex]. So does this imply that [tex]W(0)=0 \mbox{ and } W(-\infty)=0[/tex].
And one final question, Wolfram|Alpha gives a long complicated result for the inverse function of x^x involving the Lambert W function. How does one use the Lambert W function to do so?
Thanks.
For the real branches of the Lambert Function, [itex]W_{0}(x)[/itex] or [itex]W_{-1}(x)[/itex], the limit doesn't exist. The plot of x Exp[x] never dips down to -Infinity, so there is no limit. In fact, these two branches are only defined on the range [itex]x \geq -1/e[/itex]. The complex branches may have a limit as x tends to -Infinity. That may be the result that wolframalpha is giving you.
As for x = y^y, write this as x = exp[y ln y] and then take the log of both sides. Then note that y = e^(ln y). (There are some other subtleties regarding branches of the complex logarithm, but this is the basic result).
Thanks
  • · Replies 27 ·
  • · Replies 25 ·
