Quick Question about Critical Points
To identify critical points of a function defined on \mathbb{R}^2, one must find where the Jacobian is zero. Classification of these critical points is achieved by analyzing the eigenvalues of the Hessian matrix. If the Hessian has two nonzero eigenvalues, one positive and one negative, at a point where the Jacobian is zero, that point is classified as a saddle point of type (1,1). This indicates the presence of both a local maximum and a local minimum at that point.
  • Understanding of Jacobian matrices
  • Knowledge of Hessian matrices and their properties
  • Familiarity with eigenvalues and eigenvectors
  • Concept of critical points in multivariable calculus
  • Study the properties of Jacobian matrices in depth
  • Learn about the classification of critical points using Hessian matrices
  • Explore saddle points and their implications in optimization
  • Investigate the role of eigenvalues in determining the nature of critical points
Mathematicians, students of multivariable calculus, and anyone interested in optimization and critical point analysis in functions of several variables.
AKG
Say I have a function defined on all of [itex]\mathbb{R}^2[/itex] which is continuous everywhere, and of class [itex]C^{\infty}[/itex]. To find the critical points, I simply find the points where the Jacobian is zero, right (since every point in the domain is in the interior of the domain). Then, to classify the critical points, I look at the eigenvalues of the Hessian (2 x 2)-matrix. If the Hessian has only nonzero eigenvalues, one of which is positive, and one of which is negative at some point c where the Jacobian is zero, then at c, the function has a saddle-point of type (1,1). Is that correct?
Yes, that is correct. If the Jacobian is zero at some point c and the Hessian has two nonzero eigenvalues, one positive and one negative, then c is a saddle point of type (1,1).
Yes, that is correct. Finding the critical points of a function involves finding the points where the Jacobian is zero. And to classify these critical points, we look at the eigenvalues of the Hessian matrix. If the Hessian has only nonzero eigenvalues, one positive and one negative, at a point where the Jacobian is zero, then that point is a saddle-point of type (1,1). This means that the function has both a local maximum and a local minimum at that point.
  • · Replies 27 ·
