Choose the best answer on Magnetic Fields and Moving charges
The discussion focuses on determining the direction of the magnetic field affecting a current-carrying wire and calculating the magnetic field ratio between two solenoids. The first part correctly identifies that the magnetic field must be in the positive z-direction to maximize the force in the negative x-direction, as per the right-hand rule. The second part highlights the importance of using the correct formula for solenoids, specifically B = (μ₀ * N * I) / L, to find the magnetic field, emphasizing that radius does not influence the magnetic field strength in solenoids.
  • Understanding of the right-hand rule for magnetic forces
  • Familiarity with the Lorentz force equation
  • Knowledge of solenoid magnetic field calculations
  • Basic principles of electromagnetism
  • Study the right-hand rule in detail for various configurations of current and magnetic fields
  • Learn to apply the formula B = (μ₀ * N * I) / L for solenoids
  • Explore the differences between solenoids and toroids in magnetic field calculations
  • Investigate the implications of magnetic field direction on force experienced by current-carrying conductors
Physics students, electrical engineers, and anyone interested in understanding magnetic fields and their interactions with electric currents.
Physics Help!
1)A wire is carrying a current, i, in the positive y-direction. The wire is located in a uniform magnetic field, B, oriented in such a way that the magnetic force on the wire is maximized. The magnetic force acting on the wire, FB, is in the negative x direction. What is the direction of the magnetic field?
a) positive x-direction
b)negative x-direction
c)negative y-direction
d) positive z-direction
e) negative z-direction
I'm not really sure how the right hand rule 3 works for this but I just put my thumb in the direction of i and my fingers were curving downwards, so I pick e) but I'm not sure.
2. Two solenoids have the same length, but solenoid 1 has 15 times the number of turn, 1/9 the radius and 7 times the current of solednoid 2. Calculate the ratio of the magnetic field inside solenoid 1 to the magnetic field inside solenoid 2.
a) 105
b) 123
c) 144
d) 168
e) 197
I'm really not sure how to do this, I started by just plugging random numbers in for the equation B=(mu_naught*i)/(2pi*r)
I just plugged 2 for N, 3 for r, and 5 for i, and calculated the magnetic field for both and divided B of s2 by B of s1 and got 1.05E-3, I thought that that was right since I looked on the back of the book and the answer is in fact a) but I later noticed that I was using the equation for a toroid not a solenoid, since radius doesn't even affect the B of solenoids. I did the same thing with the equation B=(mu_naught*i)*(N/L) and (with L=15) got a number that wasn't on the choices, so I really don't know how to do this. Help please.
