Help with Homework Assignment: Two Puzzling Questions
The discussion addresses two physics homework questions regarding force, acceleration, and the design of mountain roads. For the first question, the acceleration of a 1 kg mass under a 1 N force is confirmed to be 1 m/s², with the velocity and distance calculations requiring further clarification. The second question explains that roads with switchbacks and hairpin turns are designed to reduce the steepness of the incline, allowing for easier ascent by minimizing the power required to climb. The principle of energy conservation is emphasized, stating that longer distances at gentler angles require less force to achieve the same work.
  • Understanding of Newton's Second Law of Motion
  • Basic concepts of acceleration and velocity
  • Knowledge of work and energy conservation principles
  • Familiarity with power and its relation to force and distance
  • Review Newton's Second Law of Motion and its applications
  • Study the equations of motion for constant acceleration
  • Explore the concept of work-energy theorem in physics
  • Investigate the design principles of road engineering in mountainous areas
Students studying physics, educators teaching mechanics, and anyone interested in understanding the practical applications of force and energy in real-world scenarios.
tucky
I am having a problem with two questions for my homework assignment.
1st question:
A force of 1 N acts on a mass of 1kg for a time of 1 s. (A)What is the acceleration of the mass? (B)What speed does the mass reach? (C)How far does the mass move?
Here is my answer but I think it is wrong:
(A) acceleration=1N/1kg = or 1 meter per second per second
(B) acceleration=change in velocity/time...I am not sure if that is the right equation to use
(C) velocity=change in average position/elapsed time ?
Then the second question that baffled me was:
in terms of power, explain why roads going up mountains are full of switchbacks and hairpin turn?
Is it something to do with the rate at which energy changes from on form to another?
I am really confused! Please help.
This one is good.
Try. What do you have to lose?
Regarding the second question: it's much harder (you need more power) to climb a steeper hill so given a mountain you build roads with a reasonable angle. At that angle you would need a longer mountain so you must make those sharp turns to keep the road on the mountain.
Sonty is completely correct.
In regards to the road, remember that "energy is conserved". Go up a particular distance requires fixed amount of work (mg times height moved) but since work= force times distance, if you go a longer distance you can do the same work using less force.
  • · Replies 32 ·
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 36 ·
