Solving Motion Equations for Conservation Laws
  • Thread starter Thread starter Goldenlemur
    Laws
The problem involves a box of mass m being dropped onto a conveyor belt moving at a constant velocity u. The discussion focuses on determining how far the box slides before matching the belt's speed and the force required to maintain the belt's speed after the box lands. Participants are exploring the equations of motion and the role of friction in this context.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants are discussing the setup of equations of motion, questioning the role of friction and whether it should be treated as a standard frictional force. There are attempts to clarify the relationship between the forces acting on the box and the implications for its motion. Some participants suggest integrating equations of motion while others consider kinematic approaches.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants have provided guidance on the use of kinematic equations and the relationship between the box's motion and the conveyor belt's speed. There is no explicit consensus yet, but productive lines of reasoning are being developed.
Participants are grappling with the implications of friction and the assumptions about the normal force acting on the box. There are also discussions about the time dependency of the distance the box slides and the forces involved in maintaining the belt's speed.
Goldenlemur
Here is the following problem: A box of mass m is dropped on a converyor belt that has constant velocity u.
a) Let friction between box and belt be nu. How far does the box slide until the box is moving at with same speed of belt?
b) What force F must be applied to the belt to keep it moving at constant speed after the box falls on it, and for how long?
My problem is setting up the equations of moition...
a) doesn't this force F need to be known for part a?
or do we just consider some other force F' where
m a = F' - nu m g
or is
m a = (dp/dt) = m (dv/dt) + v (dm/dt)
I am close or not can't get anything to work out...
I keep ending up with more unknowns in whatever setup i choose
What am not seeing?
Are you sure you are not misreading the problem and the friction isn't meant to be the usual [itex]f = \mu N[/itex]? (Where [itex]\mu[/itex] is the coefficient of friction and N is the normal force.)
Yes, frictional force suppse to be [itex]f = \mu N[/itex] I thought the normal is mg cause
[itex]0 = N - mg[/itex] ; since the block remains in contact with belt
Then you should have no problem doing part a, since the friction is the only horizontal force acting on the box.
Yes the frictional force suppose to be cofg. of friction times normal.
i thought normal was equal to the weight of the box because the box remains on the conveyor belt.
Oh the all the stuff that with linear momentum I as doing eailier was meant for part b?
I'm just finding when the box comes to rest with respect the belt and just double intergrate eq of motion to find distance traveled?
You can integrate if you like, but it's a simple kinematics problem. The force tells you the acceleration.
Additional question
The part (a) of this question shows that
distance is x = v' t + .5 (u g) t^2
where v' is initial velocity of box and (u g) the acceleration from solving equations of moition...
yet the distance the box should be indepent of time... wouldn't the distnace the box's slide depend on the magnitude of the belts velocity?
Also, having tourble with part (b):
F = (dp/dt) = (m + M) (dv/dt) + v (d(m + M)/dt)
since belt velocity is constant...
F = v (d(m + M)/dt) where v is the velocity...
so it additional ask how long should the force be appllied and what is this impluse of this force...?
am I suppose to slove for t from the eq of distance and interage F which just
impluse => is v d(m +M)
the intial momemntum and moemtum while box is sliding should be conserved
The initial velocity of the box is zero. That is just one of several kinematic equations that applies to uniformly accelerated motion. It is not the best one to solve this problem. What's another?
Why is that?
Absolutely. You need to find the distance it takes to accelerate the box from a speed of zero to the speed of the belt.
I think you are over complicating things. If you found the answer to a, then you know the distance the box had to be accelerated. Now find how long it took. If the box exerts a frictional force on the belt, what force must be applied to the belt to equalize it?
Impulse is [itex]F \Delta t[/itex].
Let me jump in here.
This is similar to the problem of a box sliding on a slippy floor (except the floor is sliding and not the box). If you look at it from the moving belts perspective, then the box is the one that is actually moving and you can find the acceleration on it (friction) and then use kinematics to determine how far the box moves until it's speed is zero (with respect to the belt).
Nothing wrong with that. Just to be clear: I take the view of the ground based frame in which the belt moves with speed v, and the box begins with a horizontal speed of zero until friction accelerates it to match the speed of the belt. Either way should work.
  • · Replies 27 ·
  • · Replies 42 ·
