A block on a frictionless slope slides down and compresses a spring
The problem involves a block of mass 2.37 kg sliding down a frictionless incline at an angle of 20.0°, compressing a spring with a force constant of 495 N/m. The block is projected with an initial speed of 0.750 m/s and travels a distance of 0.318 m before hitting the spring. The calculated compression of the spring, based on energy conservation principles, is 0.114 m, although the user suspects an error in their calculations. The alternative approach using Hooke's Law suggests a compression of approximately 0.016 m, indicating a significant discrepancy that warrants further investigation.
  • Understanding of Newton's laws of motion
  • Familiarity with energy conservation principles
  • Knowledge of Hooke's Law and spring mechanics
  • Basic trigonometry for calculating components of forces
  • Review energy conservation in mechanical systems
  • Study the application of Hooke's Law in spring compression problems
  • Learn about kinematic equations and their applications on inclined planes
  • Explore potential and kinetic energy calculations in physics
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for examples of inclined plane problems involving springs.
enthdegree
Hello, folks. I know this same problem has been answered before here but the previous responses are just not doing it for me, sorry!
An inclined plane of angle θ = 20.0° has a spring of force constant k = 495 N/m fastened securely at the bottom so that the spring is parallel to the surface as shown in the figure below. A block of mass m = 2.37 kg is placed on the plane at a distance d = 0.318 m from the spring. From this position, the block is projected downward toward the spring with speed v = 0.750 m/s. By what distance is the spring compressed when the block momentarily comes to rest?
Here is an image of such a setup.
http://imgur.com/5JF0F
2. The attempt at a solution
So basically I want to find the displacement in the spring given these values. What I do first is get the velocity at which the box hits the spring so I can get it's kinetic energy at that point.
It starts at .750m/s but it's acceleration due to gravity is 9.8*sin(20 degrees) since it's on an incline and it has to travel .318m to hit the spring so I've got:
x_final=x_initial+v_initial*t+1/2*a*t^2
.318=0+0.75*t+1/2*(9.8*sin(20 degrees))*t^2
t=0.26951 seconds
now that we have time let's get final velocity.
v_final=v_initial+a*t
v_final=0.75+9.8*sin(20 degrees)*0.26951
v_final=1.653 m/s
Now let's get the kinetic energy of the block when it hits the spring.
Kinetic=m*v^2/2
2.37*1.653^2/2=3.238J
Now let's get the potential energy on the spring
U_spring=1/2*k*(x_final^2-x_initial^2)
U_spring=1/2*495*(x^2-0)
495/2*x^2 J
now let's solve
3.238=495/2*x^2
x=0.114m. This is incorrect.
Where have I gone wrong?
Thanks!
Could you perhaps try and use hookes law to see how much it compresses directly? F=-kx, x=(2.37*9.8*sin(20))/(495)=.016? its been a while since I did physiscs so I am not 100% sure..
is the real answer really close to what you have? it could be a rounding error..
