Impact Force Comparison: Car vs. Wall Collision
  • Thread starter Thread starter sinas
    Concept
The discussion revolves around comparing the impact forces experienced during two collision scenarios: one involving a head-on crash between two identical cars and the other involving a car crashing into a stationary wall. The participants explore the implications of momentum and impulse in these collisions.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the definition of average impact force and how it relates to impulse and momentum. Questions arise regarding the assumptions made about the collisions, particularly concerning the nature of the objects involved and the implications of identical cars versus a wall.
There is an ongoing exploration of the relationship between momentum and impact force in both scenarios. Some participants suggest that the impact forces may be equal due to the conservation of momentum, while others question the assumptions about the physical properties of the cars involved. Guidance has been offered regarding the calculation of impulse and momentum, but no consensus has been reached.
Participants are operating under the assumption that the collision times are equal and that the cars do not bounce off after impact. There is also a consideration of the idealized nature of the objects involved in the thought experiment.
sinas
Consider two situations:
1) You are driving 50 mph and crash head on into an identical car also going 50 mph.
2) You are driving 50 mph and crash head on into a stationary brick wall.
In neither case does your car bounce off the thing it hits, and the collision time is the same in both cases. Which of these two situations would result in the greatest impact force? (a-hitting the car, b-hitting the wall, c-forces equal, d-not enough info)
My intuition tells me that it's A, but I've learned not to trust my intuition
Yes, it's not a good idea to trust intuition, when there's something better : definition ! :smile:
How would you calculate the average impact force on your car ? Start from the definition.
Assuming the two cars are identical, and traveling at the same speed, but in opposite directions
Imagine the vertical plane that defines where the two cars meet. Would any part of either car penetrate this invisible plane? In practice, with real world cars, they probably would, as some of the hard bits of one car would punch their way into the softer bits of the other one, and vice versa.
But if we assume the cars are made of uniform stuff, say we replace the cars in our thought experiment with solid identical lumps of steel, then there is no reason to think that any part of either lump would pass through the invisible boundary. In which case we can replace the invisible boundary with an inpenetrable, unmovable wall, and not lessen the impact in any way.
So I would say with the sorts of cars that populate the world of physics questions, there is no difference between the two impacts. But if you asked me to choose whether I would rather drive my own car into an identical car coming the other way at the same speed, or into a solid wall, I would choose the other car every time.
average force = impulse/time
If the times are the same, then it just depends on the impulse, which is change in momentum...
For the two cars..
m(50)+m(-50)=2m(0)
delta p = m(50)
For the wall..
Good.
For the two cars..
m(50)+m(-50)=2m(0)
delta p = m(50)
For the wall..
You are only interested in the change in momentum of your car in both cases. You're nearly there. How is change in momentum defined ?
(After doing this, look into ceptimus' visualization approach and see if that agrees with what you get this way)
So if your car has the same momentum going into each collision, and has 0 final momentum (mass*0 velocity?), then delta p for your car (and thus the force) is the same for each?
BTW thanks both of you for the help :smile:
15K
