Technical question about nucleation of beer?
  • Context: Undergrad
  • Thread starter Thread starter steve0606
    Beer Nucleation
The discussion revolves around the nucleation of bubbles in beer, specifically lager, and the factors that influence bubble formation in relation to the conditions of the glass used for serving. Participants explore the effects of temperature, cleanliness, and moisture on nucleation and gas release.
  • One participant notes that nucleation occurs when CO2 bubbles form at nucleation points in the glass, but questions why bubbles do not form under certain conditions.
  • Another participant suggests that beer is considered flat when CO2 has already come out of solution, indicating that some gas may still be present even if bubbles are not visible.
  • A participant clarifies that "flat" refers to the absence of apparent bubble formation, and mentions that gas can still be present, as evidenced by bubble formation when transferring beer to a different glass.
  • One participant proposes a potential explanation for the lack of nucleation related to the cleanliness and temperature of the glass, suggesting that a hot glass may still be wet and thus affect bubble formation.
  • Another participant expresses interest in conducting experiments to further investigate the phenomenon.
Participants express differing views on the reasons behind the lack of bubble formation in beer, with some proposing that cleanliness and temperature play significant roles, while others question these assumptions. The discussion remains unresolved regarding the exact mechanisms at play.
Participants mention various factors such as temperature, cleanliness, and moisture that may influence nucleation, but do not reach a consensus on their relative importance or the underlying mechanisms involved.
This discussion may be of interest to individuals studying the physics of fluids, beverage science, or those working in the hospitality industry, particularly in relation to serving carbonated drinks.
steve0606
Technical question about nucleation of beer!?
I work as a barman and am also a physics student. But I just can't seem to get my head around something: I understand that beer (referring to lager really) consists of water with CO2 dissolved in it with other, irrelevant, stuff also. You cannot see the gas because it is dissolved; however if the glass it is in contains a nucleation point (a widget) the gas is released as bubbles which float to the top of the beer and stay there. However, sometimes bubbles do not form i.e. you pour the pint and there are no bubbles being formed afterwards. My managers tell me this is because either the glass is warm, wet or dirty. But they cannot tell me WHY.
Surely, if the glass is warm, the gas should be released more readily;
I can't understand why it being wet would have much effect;
If it is dirty, nucleation should still occur.
Also, if you tap the glass the glass a flat pint is in such that it vibrates, bubbles form for a very short moment (presumably whilst the glass is stil vibrating) some bubbles form.
Can somebody please tell me why pouring lager into a widget glass that is warm, dirty or wet somehow 'deactivates' the widget unless you tap it. Thanks!
Science news on Phys.org
steve0606 said:
<snip>I understand that beer (referring to lager really) consists of water with CO2 dissolved in it with other, irrelevant, stuff also. <snip>
Heretic! :)
AFAIK, beer is flat when the CO2/dissolved gas has already come out of solution. If you see an errant bubble or two, most likely you simple was able to coax a little bit of remaining gas out of solution.
Sorry when I say "flat" I actually mean there is no apparent bubble formation. There is gas still in the beer because if I pour a "flat" pint, put into another glass, there is sometimes bubble formation like normal (even if I try this with more than 5 glasses!) Also, if the gas escaped, there is so much gas in beer that you would definitely see Effervescence due to lager being a supersaturated liquid and due to Marangoni effect.
I think I've found the answer though:
http://en.wikipedia.org/wiki/Beer_head
This explains the situations when the glass is dirty or wet and I think I may know why when the glass is hot: The glass is usually hot straight from a glasswasher. Given that a glass is used when the glass hasn't cooled down might mean that it is still wet. So it may appear nucleation is prevented from the heat of glass when really it is because the glass hasn't dried properly! Thanks anyway!
Interesting- I've never noticed that. Time to do some experiments- cheers!
  • · Replies 44 ·
  • · Replies 59 ·
13K
  • · Replies 19 ·
11K
  • · Replies 65 ·
13K
