How High Should a Marble Be Released to Propel a Steel Ball at 150cm/s?
  • Thread starter Thread starter darkdryad
The discussion focuses on calculating the height from which a 100g marble must be released to propel a 200g steel ball to a speed of 150 cm/s after a collision. The solution involves applying the conservation of energy principle, specifically using the formula mgh = 1/2 * m * v² to determine the necessary velocity of the marble. The incline angle of 40 degrees is noted, and the assumption of no friction is made to simplify the calculations.
  • Understanding of conservation of energy principles
  • Familiarity with kinetic energy formulas
  • Basic knowledge of physics concepts such as mass and velocity
  • Ability to perform calculations involving gravitational potential energy
  • Explore detailed examples of conservation of energy in collisions
  • Learn about the effects of friction on energy conservation
  • Study the impact of incline angles on object motion
  • Investigate the relationship between mass and velocity in elastic collisions
Students studying physics, educators teaching mechanics, and anyone interested in understanding energy conservation in motion and collisions.
darkdryad
I'd be grateful if anyone could help me for this question
"A 100g marble rolls down a 40 degrees incline. At the bottom, just after it exits onto a horizontal table, it collides with a 200g steel ball at rest. How high above the table should the marble be released to give the steel ball a speed of 150cm/s?"
thx
What have you tried so far?
i suppose there is no friction? In that case use conservation of total energy.
Using the formula of kinetic energy you can calculate the velocity of the marble necessary to give the ball it's given velocity.
Then use conservation of energy for the marble : mgh + 0 = 1/2*m*v² + 0
At height h the velocity is 0 and at the endpoint the height is 0...
9K
