Simple cantilever beam question
The discussion revolves around the dynamics of a cantilever beam, specifically focusing on the differential equation that describes the change in position of the beam's tip over time when plucked. Participants explore various aspects of cantilever beam behavior, including oscillations, damping effects, and the mathematical modeling of these phenomena.
  • One participant seeks the ODE for the tip's position over time after plucking the beam, expressing difficulty in finding it in textbooks.
  • Another participant suggests that the change in position over time can be derived from basic principles, encouraging the original poster to think through the problem.
  • A different participant introduces the concept of simple harmonic motion (SHM) and proposes a relationship between deflection and angle, leading to a derived ODE based on assumptions about mass distribution.
  • Concerns are raised about the need to eliminate certain variables (like angle) from the equations presented.
  • One participant references the Euler–Bernoulli beam equation and discusses the effects of damping on the system, noting that the complexity of the problem may exceed introductory material.
  • Another participant questions the relevance of air damping, suggesting it may be negligible, while also drawing parallels to the motion of a simple pendulum.
  • Confusion is expressed by multiple participants regarding the complexity of the derivation and whether it is indeed straightforward as some claim.
Participants do not reach a consensus on the simplicity of the derivation or the necessity of including damping effects. There are multiple competing views on how to approach the problem and what assumptions are valid.
Participants acknowledge limitations in their assumptions, such as the uniform distribution of mass and the effects of damping, which remain unresolved. The discussion highlights the complexity of deriving the ODE and the varying levels of familiarity with the topic among participants.
Andrew732
I've been looking at the equations describing different aspects of cantilever beam dynamics, but I can't seem to find what I'm looking for. (And I'm not smart enough to derive it.) If I pluck the tip of the beam and measure the location (x) of the tip over time (t), it should look something like this picture I found on google image search:
http://www.roboticunicycle.info/images/Cantilever beam L=0.6.jpg
What is the ODE that describes dx/dt? Is this so simple that nobody actually talks about it? Thanks for any help~
Well what is dx/dt? It is the change in position over time. So you will have to use positions at incrementally increasing times (i.e. v2-v1, v3-2, etc)
You aren't "not smart enough" to derive the equation, something like this isn't that tough. "deriving" this equation is just thinking it through and understanding what output you want.
OK, I appreciate the encouragement but this is not a homework question and physics/engineering is not my field. Surely this is in a textbook somewhere? I'm not sure why I can't find it. Any ideas?
hi!
I have seen a lot of questions on cantilever beams, but I am not familiar with this type. generally we're asked only to find out the maximum deflection at the tip, but you need the change in deflection with respect to time. so you have a case of SHM.
suppose you bend a cantilever by loading it at one end. the cantilever will now have an angle θ, (say) with respect to the original position. so if we consider really small angles (i.e. really small loads) we can approximate the deflection(x) as:
x= length of the cantilever(L)*θ
now if we take the moments about the pivot point (the point where the cantilever is attached to the wall), we have from Newton's second law ( Ʃtorque= Iα)
mass moment of inertia of the system about the point (J)* angular acceleration(double differential of θ, let's give it a symbol DDθ) = algebraic sum of moments about the pivot point.
at this stage I'm assuming that the mass of the rod is uniformly distributed, and therefore the centre of mass lies at the centre of the rod i.e. at a distance of L/2 from the pivot point. ( this assumption maybe wrong, but this is the only way i know how to do this)
J*DDθ=m*g*L*θ
(m*L*L*cosθ*cosθ)/(4) *DDθ= m*g*l*θ
this shd be your ODE. correct me if I'am wrong.
sorry for the stupid symbols and stuff like L*L. don't knw how to work this.
waiittt.. we need to eliminate theta... i'll get back on tht after i take a nap
Thanks for the replies~
So at any rate this does seem to be somewhat beyond "Cantilever Beams 101" and the type of thing that would be listed in any textbook. OK, well let me take a look at what's been posted here and see if it makes sense.
alpha zero;
I know that its damping. it would be damping anywhere on Earth that's without a vacuum. but don't you think we should ignore the damping caused by air?... it will be pretty small.
if there was a damper attached somewhere then you should have considered damping.
this case is very similar to a simple pendulum undergoing oscillations. now the differential equation describing its motion is l*DDθ+gθ=0
but how does the pendulum stop if it isn't damped?.. it is damped but only a little by the air friction.. maybe the time period for such a case is huge...!
if we do take in the damping into consideration i'am getting this equation:
F=-mgcosθ/2-mlDDθ/4... where F is the damping force...
i can show you how i got this if you guys are interested... now that we have this though how do we find the damping force of air?
the more i post on this the more confused i get
I'm confused too, and I do appreciate the time that you're spending on this.
I've taken basic diff eqs, but this seems to be much harder than I would have expected, very different from forced springs and similar things. Now I'm starting to see why it's not just right there in any textbooks. Do you people who claim that it's a straightforward derivation actually know for a fact that it is, or are you just assuming?
41K
21K
  • · Replies 34 ·
