Calculating Time Constant for Spring Oscillations
  • Thread starter Thread starter guru
    Oscillations
This discussion focuses on calculating the time constant for spring oscillations involving a spring with a spring constant of 11 N/m and a mass of 0.540 kg. The time period of oscillation is determined using the formula T = 2π√(m/k), resulting in T = 0.9809 seconds. The decay constant (λ) is calculated as 1.019 s-1, leading to a time constant (τ) of 0.981 seconds. Finally, the amplitude after 31 oscillations is derived using the formula A = A0e(-λt).
  • Understanding of Hooke's Law and spring constants
  • Familiarity with the concepts of oscillatory motion
  • Knowledge of exponential decay in physics
  • Ability to manipulate mathematical formulas
  • Study the derivation and applications of the formula T = 2π√(m/k)
  • Learn about the characteristics of damped oscillatory motion
  • Explore the relationship between decay constant and time constant in oscillatory systems
  • Investigate practical applications of spring oscillations in engineering
Physics students, mechanical engineers, and anyone interested in the dynamics of oscillatory systems will benefit from this discussion.
guru
A spring with spring constant 11 N/m hangs from the ceiling. A .540kg ball is attached to the spring and allowed to come to rest. It is then pulled down 6.2cm and released.
I need to find the time constant if the ball's amplitude has decreased to 2.8cm after 31 oscillations.
I need help on how to approach this problem
You have all the information you need to find the period of oscillation, do that. You also should have the governing equation for damped oscillatory motion. You know the amplitude of motion at 2 different times. Use that information to find your damping coefficient.
If you have more questions, please share with us what you have as for the equation of motion of a damped oscillator.
To calculate the time constant for spring oscillations, we can use the formula T = 2π√(m/k), where T is the time period, m is the mass attached to the spring, and k is the spring constant.
In this problem, the mass of the ball is 0.540kg and the spring constant is 11 N/m. To find the time constant, we need to first calculate the time period of the oscillation.
Step 1: Calculating the time period
To find the time period, we can use the formula T = 2π√(m/k). Plugging in the values, we get:
T = 2π√(0.540kg/11 N/m)
= 2π√(0.04909 kg/m)
= 0.9809 s
Step 2: Calculating the decay constant
The decay constant (λ) is equal to 1/T, where T is the time period. So, λ = 1/0.9809 = 1.019 s^-1
Step 3: Calculating the time constant
The time constant (τ) is equal to 1/λ. So, τ = 1/1.019 = 0.981 s
Step 4: Finding the amplitude after 31 oscillations
To find the amplitude after 31 oscillations, we can use the formula A = A0e^(-λt), where A is the amplitude, A0 is the initial amplitude, λ is the decay constant, and t is the number of oscillations.
2.8cm = A0e^(-1.019 s^-1 * 31 oscillations)
2.8cm = A0e^(-31.589 s^-1)
A0 = 2.8cm / e^(-31.589 s^-1)
A0 = 2.8cm / 0.000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  • · Replies 18 ·
