Conservation of energy in projectiles
The discussion focuses on the conservation of energy in projectile motion, specifically analyzing the height at which a projectile launched vertically upward with an initial speed v reaches a speed of 0.5v, and the maximum height of a projectile launched at an angle theta. The maximum height (hmax) for the vertical launch is derived as v^2/(2g). For the projectile launched at an angle, the maximum height is calculated as v^2(sin(theta))^2/(2g). The participants clarify the importance of separating kinetic and potential energy in these calculations.
  • Understanding of conservation of energy principles
  • Familiarity with projectile motion equations
  • Knowledge of kinetic and potential energy formulas
  • Basic trigonometry for analyzing angles in projectile motion
  • Study the derivation of projectile motion equations in detail
  • Learn about energy conservation in non-vertical projectile launches
  • Explore the effects of air resistance on projectile motion
  • Investigate the role of initial launch angles in determining projectile trajectories
Students and educators in physics, engineers involved in projectile design, and anyone interested in understanding the principles of energy conservation in motion.
disruptors
an object launched vertically upward with an initial speed v. Neglect air resistance
a)At what height h above the ground does the projectile have a speed of 0.5v? Express your answer in terms of v and the magnitude of the acceleration of gravity g.
Using conservation of energy i found the max height (hmax) to be v^2/(2*g)
i then came to find h at a speed at 0.5v to be (v^2/(2*g))/4. However it says i am off by a multiplicative factor. I tried to take in account the KE and PE but am confused...
b) A ball is launched as a projectile with initial speed v at an angle (theta) above the horizontal. Using conservation of energy, find the maximum height (hmax) of the ball's flight. Express your answer in terms of v, g, and theta
i thought it would be v^2/(2*g) and its not which makes me wonder why?
thanks
I got :
[tex]\frac{mv^2}{2} = \frac{1}{2}*m* \frac{v^2}{2^2} + mgh[/tex]
solve this for h...
thanks
at the max heigth, the y-component of the velocity (=v*sin(theta)) is 0.
[tex]\frac{1}{2}*m*v^2 = \frac{1}{2}*m*(v*cos(\theta))^2 + mgh_{max}[/tex]
regards
marlon
for the question and explanation!
a) To find the height at which the projectile has a speed of 0.5v, we can use the conservation of energy equation:
Initial kinetic energy + initial potential energy = final kinetic energy + final potential energy
At the highest point of the projectile's motion, its kinetic energy will be 0 since its speed is 0. Therefore, the equation becomes:
Initial potential energy = final potential energy
We can express the initial potential energy as mgh, where m is the mass of the projectile, g is the acceleration due to gravity, and h is the initial height. The final potential energy can be expressed as mg(hmax), where hmax is the maximum height reached by the projectile.
Setting these two equal, we get:
mgh = mghmax
Dividing both sides by mg, we get:
h = hmax
Therefore, the height at which the projectile has a speed of 0.5v is equal to the maximum height reached by the projectile, which we found to be v^2/(2*g).
b) To find the maximum height of the ball's flight, we can use the same conservation of energy equation as before. However, this time we need to take into account the initial angle, theta, at which the ball is launched.
The initial kinetic energy can be expressed as 1/2mv^2, but since the ball is launched at an angle, only a component of this initial kinetic energy will contribute to the projectile's vertical motion. This component can be expressed as 1/2mv^2(sin(theta))^2.
The final kinetic energy will still be 0 at the highest point of the ball's motion.
Therefore, our equation becomes:
1/2mv^2(sin(theta))^2 + mgh = 0
Rearranging, we get:
h = v^2(sin(theta))^2/(2g)
This is the maximum height reached by the ball, expressed in terms of v, g, and theta.
  • · Replies 18 ·
  • · Replies 38 ·
