Why is the Gravitational Potential Energy formula negative?
The discussion centers on the nature of gravitational potential energy, particularly why the formula for gravitational potential energy is negative and how this relates to the concept of potential energy in general. Participants explore theoretical implications, mathematical formulations, and conceptual understandings related to gravitational fields.
  • One participant notes that lifting a book increases its potential energy, but questions why the gravitational potential energy formula for planets is negative.
  • Another participant explains that gravitational potential energy is considered 'negative' because masses attract each other, contrasting it with electric charges that repel.
  • A different participant clarifies that the negative sign arises from choosing a reference point at infinity for potential energy, suggesting that this is a matter of convenience in calculations.
  • One participant discusses the use of the formula mgh for constant gravitational acceleration and how it relates to changes in gravitational potential energy when lifting an object.
  • Another participant illustrates the concept of negative potential energy through integration, showing how the direction of force affects the sign of potential energy.
Participants express differing views on the interpretation of negative potential energy and the implications of reference points in calculations. There is no consensus on a singular explanation for the negative sign in the gravitational potential energy formula.
The discussion highlights the dependence on chosen reference points for potential energy and the implications of gravitational attraction versus repulsion in different fields. Some assumptions about the constancy of gravitational acceleration and the mathematical treatment of potential energy are also present.
Kyle91
Hey guys
So if I lift a book from the ground it gains potential energy. I do work on the book and when I release it the potential energy that I gave the book pulls the book back down to Earth.
However I was looking at a potential energy formula for planets which was
V = -GMm/r
But this doesn't make sense because a) why is potential energy negative and b) why does the absolute value of it get smaller with increasing r? The potential energy should increase with increasing r (it does, but because I don't understand the negative sign I'm thinking of its absolute value).
Cheers
the potential energy of electric charges works exactly as you think it should. This is because like charges repel.
the potential energy of gravitational fields is considered to be 'negative energy' because masses attract rather than repel each other. Otherwise the total energy of the system would not be constant.
Your choice of a zero really makes no difference during calculations since you take the change, the reason that the formula is negative is because we take the zero of potential energy at infinity. It might seem odd at first but potential energy is calculated as the work in going from your zero to your end point (the point who's potential you are trying to find). If you want the zero to be at the centre of the object you're measuring against (planet, star etc) you get a division by zero, so instead we take the zero as infinity as a matter of convenience :)
When the acceleration due to gravity is approximately constant, we take any convenient zero reference for the gravitational PE and we can use mgh for the change in gravPE. For example when I lift a book one usually takes the original position of the book to be the zero reference level for gravPE. Then as the original poster said, the work done in lifting the book will be the increase in gravPE in book.
But when the acceleration due to gravity is varying appreciably one must use
gravPE = -GMm/r.
As I lift a book the work done against the pull of gravity will increase its gravPE. Since r will be increasing, then GMm/r will decrease. But increasing r will INCREASE this PE since the gravPE is negative.
See this
If the direction pointing from the ground is positive(it usually is), then the direction of gravitational force is negative(they're opposite, ain't they?)
...Λ...|...
__|_______V_____
For this system
That is V = ∫Fdx = ∫m(-9.8)dx = -9.8mx [integrate over upper direction:x>o]----->we have negative potential.
It can also be this(if you want):
...Λ...|...
__|_______V_____
For this system
That is V = ∫Fdx = ∫m(9.8)dx = 9.8mx [integrate over upper direction:x<o]----->we also have negative potential.
  • · Replies 46 ·
  • · Replies 54 ·
  • · Replies 27 ·
12K
