Probability Teaser Puzzle - Challenge Your Mind
  • Thread starter Thread starter DaveC426913
    Probability
The discussion revolves around a probability puzzle that challenges participants to determine the correct answer from a set of options, with a focus on the implications of randomness and correctness in the context of the question. The scope includes exploratory reasoning and mathematical reasoning.
  • Some participants express uncertainty about the nature of the question and what it means for an answer to be 'correct'.
  • One participant suggests that if answers A and D are the same, then the probability of choosing 25% as the correct answer is 50%, which contradicts the stated probabilities.
  • Another participant argues that if one chooses randomly, there is a 50% chance of picking either A or D, while only B offers a choice of 50%, leading to the conclusion that A and D must be correct.
  • A participant proposes that without knowing the question, one cannot determine the probability of being correct, suggesting a 33% chance if chosen at random.
  • There is a discussion about the assumptions needed to determine a correct answer, with one participant noting that context is crucial and that randomness may not be evenly distributed.
  • Another participant presents a forensic analysis suggesting that answer A is the correct one based on handwriting analysis and formatting inconsistencies in the answers.
  • Some participants highlight the paradoxical nature of the question, indicating that certain questions may lead to contradictions.
Participants do not reach a consensus on the correct answer or the nature of the randomness involved. Multiple competing views remain, with various interpretations of the probabilities and assumptions at play.
Participants note the limitations of the information provided, including the ambiguity of the question and the assumptions required to arrive at a conclusion. There is also mention of the potential for biased randomness affecting the outcome.
Individuals interested in probability puzzles, logic challenges, and discussions surrounding assumptions in problem-solving may find this thread engaging.
DaveC426913
2025 Award
[PLAIN]http://chzdailywhat.files.wordpress.com/2011/10/0b666cba-9278-4ab2-8794-46160e3b24c7.jpg
Mathematics news on Phys.org
none of the answers is correct.
Part of my brain thinks it's a trick question. What does it mean to be 'correct'?
What is the question?
I ... don't know...
I can't actually reformulate it...
I'm missing the answer 0%. ;)
my head hurts
There is a 50% chance you will choose 25% and a 25% chance you will choose 50%.
So...60% is my final answer.
The correct answer is (A) and you have a 25% chance of getting it right.
A & D are the same answer, so the chances of "25%" being the correct answer is 50%, which contradicts their stated probabilities, so neither can be right.
That leaves B & C, and so since both are equally probable, means B is the only right answer
so... if I randomly choose from the four answers, there is a 50% chance I will choose B?
It can either be A&D or B.
If one chooses at random, then there's a 50% probability to pick either A or D. Only B offers the choice of 50%. Thus there's a 25% chance of picking B and thus A&D are correct.
though correct me if I'm wrong, I'm about to pass out due to tiredness.
I choose <A| + <D|.
Quantum mechanically speaking this is correct ("bra-ket" notation).
It will take me 2 seconds to answer that question.
We don't actually know the question, so we can't know the answer. It is asking what is the probability of choosing the correct answer, not what the actual answer is. There are three different answers, so chosen at random wouldn't you have a 33% chance of being correct?
EDIT: Looking back at it I realize it probably isn't that simple. But it sounded good at the time.
None
assumptions:
-"random" means our choice is a uniformly distributed random variable
-the problem can have at most one correct answer even if it is stated by many possible choices
(for example, the answer can't be both 50% and 25% but it can be both A and D)
(attempt at a) solution:
*Let's suppose that A is the correct answer.
Then D is the correct answer also, since they state the same thing.
Therefore, the chance of hitting a correct answer is .5. Therefore, B is the correct answer which is contradictory. So A can't be the correct answer.
*Under the same reasoning, D can't be the correct answer
*Let's suppose B is the correct answer.
Thus the chance of hitting a(the) correct answer is .25. Thus A or D is the correct answer, which is contradictory.
*same goes with C
Therefore none of the above answers is correct.
That was fun! (or might still be if I got it wrong!)
Are my assumptions wrong?
Is the solution wrong?
Hats off to Constantinos. My head exploded!
This assumption is incorrect. For example, take questions #6 and #17 of this test. B/D and D/B would seem to be correct answers for both questions, but there is only one correct answer for each question.
You need the entire test to know for sure whether A or D (or both) is the correct answer. Depending on the context, a random choice could still have only a 25% chance of being correct, even when two choices list the same answer - and even if there's not enough information provided to know which choice listing 25% is the correct answer.
Edit: However, there does have to be some assumption made in order for there to be a correct answer. For example, there are 26 letters in the English alphabet, 28 in the Spanish alphabet, and 33 in the Cyrillic alphabet. Since the question is written in English, assuming they're talking about picking a random letter in the English alphabet would be a good assumption - except picking a random letter would have less than a 25% chance of being correct - meaning there must be some other limiting assumptions made, as well.
Admittedly, although they specify "random", they don't actually specify that the randomness is evenly distributed. It could be random with a bias, in which case it's not possible to determine the answer, despite the fact that there might be a correct one.
DaveE
Forensic analysis indicates the correct answer must be A.
All of the numbers except one were written by the same person. The handwriting style of the '2' in answer D is different than the handwriting style used for the other numbers.
Additionally, most of the erasure marks on the board match the circular motion used to erase a large amount of data. The almost straight line erasure mark coming from the '2' in answer D indicates a very small amount of data was erased while taking care not to erase other data.
Furthermore, proper testwriting technique requires the choices to be written in some sort of logical order: shortest to longest, longest to shortest, smallest to largest, etc. A, B, and C are properly formatted with each answer giving a higher percentage, and then D suddenly presents a lower percentage. D clearly was originally 65%, 75%, 85%, or 95%.
Answer D was altered to maliciously mislead the masses.
Like Constantinos, showed, its unanswerable.
There are lots of questions that can't be answered without creating contradiction.
For eg.
Answer in Yes or No, Will your answer be 'No' ?
9K
