Why Doesn't Linearity of Integrals Apply to Differential Forms?
The discussion clarifies that the linearity of integrals does not apply to differential forms, specifically when evaluating the integral of the form zdx + xdy + ydz over directed line segments in R³. Unlike traditional integrals, the integral from point a to point c does not equal the sum of the integrals from a to b and b to c due to the geometric nature of differential forms. It is established that only exact differentials, represented as df for some function, maintain this property in simply connected regions. The concept of closed differentials, which have a curl of zero, is also introduced as related to the topology of the region.
  • Understanding of differential forms and their properties
  • Familiarity with concepts of exact and closed differentials
  • Basic knowledge of topology, particularly simply connected regions
  • Experience with vector calculus in R³
  • Study the properties of exact differentials and their applications
  • Learn about closed differentials and their significance in topology
  • Explore Riemann cohomology and its role in measuring connectivity
  • Investigate the geometric interpretation of differential forms in integration
Mathematicians, students of advanced calculus, and anyone studying differential geometry or topology will benefit from this discussion, particularly those interested in the properties and applications of differential forms.
eddo
I'm just learning about differential forms and I've noticed something in my homework assignment. We have to evaluate
zdx + xdy + ydz, over directed line segments in R-three by the method of pullback. Let a, b, and c be vectors in R-three. I noticed that Integral from a to c does NOT equal integral from a to b + integral from b to c, as it does with normal integrals. I think that this would make sense, since the meaning of zdx +xdy +ydz, which you are integrating, depends on the line segment in question. Is it true that this rule does not apply with these kinds of integrals, or have I simply made a mistake somewhere in my calculations? Thanks.
you are right! there is however a special class of integrals, i.e. differential forms, that DO give the same integral over any path joining the same two points. these are called "exact" differentials, and are precisely those of form df for some function in that region, i.e. a gradient.
another related concept is of a "closed" differential, one such that its curl is zero. these are in fact the same as the exact differentials in any "simply connected" region.
thus to measure how far a region is from being simply connected, one can ask how many closed differentials fail tro be exact.
for example, if we remove n points from the plane, there will be exctly an n dimesnional vector space of closed forms in that region, if we consider all exact forms to be zero.
\this measuring device isa big tool in topology called rerham cohomology.
so you have just noticed one of the most imporatnt question in the subject!
work done by gravity for example is exact so does not depend on the path taken by the object.
Yes, you are correct in your observation. The rule of splitting integrals into smaller segments does not apply to differential forms. This is because differential forms are not just functions, but they also have a geometric interpretation. When integrating a differential form over a directed line segment, the result depends on the specific path taken along that line segment. This is because the differential form is being pulled back along that path, and the value of the form changes as the path changes. So, it is not possible to split the integral into smaller segments and add them together. This is a fundamental difference between normal integrals and integrals of differential forms. Keep up the good work in your studies!
  • · Replies 73 ·
9K
