QPSK modulation/demodulation spectra
  • Thread starter Thread starter solanojedi
    Spectra
This discussion centers on the analysis of QPSK (Quadrature Phase Shift Keying) modulation and its spectral characteristics, particularly in relation to the structures presented in Lee-Messerschmitt's "Digital Communications." The user Nicola explores the discrepancies in spectral outputs when using different receiver configurations, specifically comparing a complex filter setup to traditional mixer and low-pass filter arrangements. Key questions arise regarding the asymmetry of sidebands in quadrature modulated signals and the reasons for differing results in receiver chains.
  • Understanding of QPSK modulation techniques
  • Familiarity with digital signal processing concepts
  • Knowledge of spectral analysis and filtering techniques
  • Experience with complex signal representations
  • Study the principles of QPSK modulation and demodulation
  • Examine the effects of different filtering techniques on signal spectra
  • Research the implications of asymmetric sidebands in digital communication
  • Review Lee-Messerschmitt's "Digital Communications" for deeper insights
Engineers and researchers in telecommunications, digital signal processing specialists, and students studying advanced modulation techniques will benefit from this discussion.
solanojedi
Hi everybody,
I'm reading about digital modulation (in particular on Lee-Messerschmitt's Digital Communications) and I have this picture (RX.jpeg attached). These three structures are equivalent: so, at the end of each structure, I should have the same spectrum.
I tried to think what can happen to the spectrum of a received signal in the third case (analytic bandpass filter) and I tried to design some spectra shapes ( like they do @pag.13 of this article http://www.eumus.edu.uy/eme/cursos/dsp/material/Lyons_Quadrature.Signals.pdf ) .
In the case with a complex filter I found those spectra pictured in the attached figure RXchain.jpg, but if I multiply the Q-path signal by j and then sum to the I-path signal (like they do in the paper of Lyons) I DON'T obtain the same signal that I have from the structure with two mixers+low pass filter.
So, here my questions:
1) First of all, why the spectrum of quadrature modulated signal have the two sidebands asymmetric? How do they create such signals?
(I have found this paper http://www.google.it/url?sa=t&rct=j...sg=AFQjCNG_YGRcmbHMX2i7-KkwVyFHAjJtkA&cad=rja where in Fig. 1(a) they represent some baseband spectra QPSK but I don't know if they are correct..)
2) Why the receiver chain with the complex filter doesn't give the same result as the other two structures?
Thank you if you can help me or suggest me some book that can explain!
Nicola
