Is the Order of Applying Restrictions Commutative in Set Theory?
  • Context: Graduate
  • Thread starter Thread starter DarkFalz
The discussion centers around the question of whether the order of applying restrictions to a set of numbers is commutative in set theory. Participants explore this concept through examples and logical reasoning, focusing on specific restrictions and their implications for subsets.
  • One participant asserts that applying two restrictions over a set can be done in any order, seeking proof for this claim.
  • Another participant counters that the order of restrictions is not generally commutative, using matrices as an example where order matters.
  • A participant clarifies their question by specifying the restrictions as numerical conditions (e.g., X<4 and X is even) and asks for a general proof of commutativity in this context.
  • It is suggested that defining a new set based on elements satisfying both properties implies that the order of applying restrictions does not matter.
  • One participant proposes explaining the concept in terms of subsets, questioning how to prove that applying restrictions in different orders yields the same results.
  • Another participant agrees that logical "and" is commutative, suggesting this resolves the question regarding the order of restrictions.
  • A further elaboration on the subset argument is presented, detailing how elements satisfying both restrictions will belong to the same resulting sets regardless of the order of application.
Participants express differing views on the generality of commutativity in applying restrictions. While some argue that it holds true under specific conditions, others maintain that it is not universally applicable, particularly in broader contexts.
The discussion involves assumptions about the nature of the restrictions and the sets involved, which may affect the conclusions drawn. The specific definitions of the restrictions and the sets are crucial to the arguments presented.
DarkFalz
Hello,
i've always believed and accepted that applying two restrictions over a set of numbers N can be done in any order. Let's consider we want to apply the restrictions R1 and R2 over the set N,
how can it be proved that the order in which we apply the restrictions does not matter for the final result?
Thanks in advance
It isn't true in general. If by a "set of numbers N" you mean really any set of numbers, then for example we can take two matrices A and B. These are indeed two "sets of numbers", but the order of the restrictions on them matters. Ex: A x B (cross product if they are vectors in R3) ≠ B x A (Non-commutative), also AB≠BA (Multiplication of matrices is non-commutative in general.)
For your question, if you indeed think that you have a set of numbers for which commutativity holds, all you have to do it apply the R1 restriction one way, apply the R2 restriction, and then show that both of these restrictions come out to the same thing.
I should have explained my question in a better way. I was referring to restrictions such as these ones:
R1: X<4
R2: X is even
I have a set N such as {1,2,3,4,5,6,7,8,...}
If i apply R1 and then R2, how can it be proved for a general case that is it the same as applying R2 and then R1?
So you have a set, and you define a new set by letting the elements be all those elements of the original set which satisfy both properties? Clearly the order doesn't matter, because A and B ==> B and A.
I would like to explain it in terms of subsets. Let's say that by applying the restriction R1 over N generates Nr1, and applying the restriction R2 over N generates Nr2, how can i prove that by applying R2 over Nr1 and R1 over Nr2 has the same results?
Jamma is right. Logical "and" is commutative, therefore...you're done. That's it. You're dealing with an axiom of logic.
Because, as I said, "and" is commutative. If Nr1 is the set generated by restriction R1 and Nr2 is the one given by the restriction R2, then Nr1 restricted to R2 is, by definition, elements of S that first satisfy R1, and of those they need to satisfy R2 also. Hence, they will all satisfy R1 and R2. Conversely, if an element satisfies R1 and R2, then it will be in Nr1 restricted with R2.
Analogously, something is in Nr2 restricted by R1 if and only if it satisfies firstly R2 and secondly R1 i.e. it is the set of elements satisfying R2 and R1.
If something satisfies R1 and R2, then it satisfies R2 and R1 (commutativity of and) and hence is in Nr2 restricted by R1. Hence Nr1 restricted by R2 is a subset of Nr2 restricted by R1. Analogously, Nr2 restricted by R1 is a subset of Nr1 restricted by R2, so the two sets are equal.Explaining all that seems a bit like overkill.
  • · Replies 27 ·
  • · Replies 36 ·
  • · Replies 28 ·
